587,203 active members*
3,283 visitors online*
Results 1 to 7 of 7
    Jun 2011
    New 4x4+ plasma table project
    Hey everybody,
    new member, long time lurker...anyways started putting some of my components together believe I might have an issue...
    table is going to be a 4'+ x 4'+ water table, all ball screw.
    BTW - all parts used and cheap.. except for plasma unit, steppers and driver/PS
    X and Y are 55" THK linear actuators that appear to be standard NEMA 23 motor mounts.
    Z is some weird but cool looking servo driven ball screw (see pics)
    PROBLEM IS: The servo on the Z is a Rockwell Samsung model CSMT which by all accounts measures at 46mm bolt circle (close to nema 17 but not...) attached to a planetary reduction unit which is a Neugart PLE 40.
    I'm hoping somebody out there knows what can be done here? I'm thinking adapter plate? but don't see any existing for this app?
    I'd love to keep the gear reduction and adapt it to NEMA 23 or NEMA 17? Anybody have any ideas???
    Jun 2011
    Anybody have any advice? Neugart is of no help...so far. Nobody here has replaced a servo with a NEMA 17 or 23 stepper?
    Feb 2008
    153
    That's some nice looking hardware you've got. I don't think you will want to use the planetary reduction on the Z axis. You may need to make your own adapter or modify the plate to mount the motor directly.
    Jun 2011
    Fiero Addiction, Thanks for reply.
    Just a dumb question but.. do they purposely make servos different bolt patterns then steppers?
    I was under the impression that they were interchangeable (provided you have the necessary electronics to run what you wanted)?
    Jun 2011
    Just updating this thread.. made a little progress lately.
    The THK linear ball screw rails are model GL20 's with NEMA 34 adapters.
    The Z is custom (repurposed piece from EBAY) as said before.. being driven by NEMA 23.stepper. I had the motor adapter machined after getting the run around by the the gear reduction manufacture. The stand offs are just threaded rod nuts adapted together. I spun the center adapter up on a mini lathe to convert the NEMA 23 .250" shaft to the gear reduction's 8mm input.
    Jun 2011
    I used 5/8' aluminum plated and had two uprights waterjet'd to connect the Y axis to the X axis.
    Jun 2011
    Just another update... the X and Y come together finally. On to Mcmaster Carr to find more hardware.
  1. Precision Plasma LLC 2' x 3' DIY Plasma Table
    By rchacich in forum News Announcements
    Last Post: 08-26-2011, 12:05 AM
  2. 4 x 4 Plasma table project
    By jermu in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-02-2010, 08:28 AM
  3. Precision Plasma LLC 5' x 5' CNC Plasma Table
    Last Post: 11-10-2009, 05:08 PM
  4. 3x2m plasma table project/log
    By bekx in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 05-07-2008, 05:57 AM
  5. 5 x 10 table for plasma / tourch / router - project
    By ajclay in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 03-21-2008, 12:30 AM
