Assuming that you didn't want to build your own plasma table, here is an option for a high quality 4x4 table with digital torch height control for under $5K.
This is a high quality table utilizing extruded aluminum rails with hardened v-guides, hardened v-guide wheels, 1/8" sheet metal frame that is powdercoated, 1/2" machined aluminum plates, machined wheel and gear covers with rail wipers/oilers, and a high quality Z axis with floating torch switch for touch and go plasma cutting. The slats are not included since the 1/8" x 3" HRS is more expensive to ship than to purchase locally.
A stainless water pan with integrated slat holders is also an option, but we also suggest using our print and sourcing locally to save money.
The only way to get a table of this quality at this price is to purchase the mechanics and electrical package seperately. The recommended electrical package for use with this machine is the Bladerunner AIO 300-4 with Dragon Cut Digital Torch Height Control from candcnc.com.
In this senario, support from the mechanics would come from Precision Plasma LLC and support for the electronics would come from Candcnc.com. This seperation is what reduces the cost.
Costs:
Precision Plasma LLC bolt together kit $3450
Candcnc.com Bladerunner AIO 300-4 Dragon Cut $1250
Sheetcam and Mach 3 software package from candcnc.com $299
Total $4,999 + shipping
If you were interested in welding up your own frame, you could build a 4x4 table for under $4k and a 4x8 table for under $4.5K
