Originally Posted by
NIC 77
I am absolutely not an expert on this.
Hey that makes two of us .. isn't this blind leading the blind!!!
Have you tried plugging the A motor into the Y plug and the Y motor into the A plug of your electronics box? Can you do that or are you hardwired throughout? It looks like you've done everything but this.
If the Y motor then only moves in a positive direction then you know it's probably not your motors / cables.
If however the A motor still behaves the same when plugged into the Y plug then you know it's something wrong with the motor / cable and not your software or computer.
Ger21 suggested this. Went back to studio, tried it. No luck. Also, had checked out the A-motor by switching it with X-motor during the first go around. No change after that either.
As far as the humming, I'm curious, do you have resistors wired in and if so where? OK, I see you're using the soigeneris products. Hmmm...don't know.
Haven't done the G540 "tuning" yet .. maybe it will disappear after that.
Do you have another computer you can try?
Mind reader .. going to set another one up tonight. Hope this works as I cannot figure what else it could be.
