587,999 active members*
1,719 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Ballscrew Coupling and thrust bearing mount plate.
Results 1 to 3 of 3
    Jan 2008
    45
    Well now that everyone has helped me fix the oiling problem on the 6030. We had the machine cutting and the side of the thrust bearing plate blew out!! on X axis. Also discovered that the ballscrew to servo coupling is a boston gear resilient coupling with a blue urethane spider.( Could have also contributed to the increasingly poor finish.) The ballscrew is smooth and so is the table movement. The plate shows signs of being broken for sometime. We are in the process of making a new plate. Does anyone have a coupling brand or style they recommend? Thanks In Advance!!
    Jul 2009
    317
    The original fadal couplers where cast alum then switched to cold roll with a yellow spider that later the switched to Delrin.
    Mar 2010
    The fadal replacement parts would be mtr-0155 for the 2-lobe derlin (I prefer these,rigid steel coupling w/derlin insert, less trouble).or the mtr-0189 4-lobe zero backlash type, these are clamp stye,the 2-lobe is key and set screw type.i have seen the 4-lobe ones break but not the 2-lobe type.
  1. How to mount thrust bearings
    By Spitfire in forum Linear and Rotary Motion
    Last Post: 07-17-2015, 05:42 PM
  2. Replacing Y axis Ballscrew/thrust bearings.
    By steedspeed in forum Haas Mills
    Last Post: 06-28-2014, 09:24 AM
  3. thrust bearing ?
    By slowlearner in forum Fadal
    Last Post: 07-17-2011, 03:08 PM
  4. help for mount bearing ballscrew
    By p_rabid in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 09:11 AM
  5. Position of thrust bearings on ballscrew
    By M100 in forum Linear and Rotary Motion
    Last Post: 08-10-2007, 05:25 PM
