587,481 active members*
3,110 visitors online*
Results 1 to 11 of 11
    May 2009
    393
    Is there any way to avoid % sign ?
    On my VMC, I normally use a DPRNT Command.
    But the problem is that " % " sign occurs at the start & end of program.
    As you can see in the attached figure, I commanded DPRNT to get the actual time and date from the machine, but I got unnecessary character (% sign) at the start & end of file.
    Is there any way to avoid such % sign ? ?
    Ashish
    2932
    What control? What communication software?
    May 2009
    393
    Machine - Pinnacle 1100S
    Control - Mitsubhishi
    Feb 2010
    371
    I don't know about the starting % sign, but my understanding is the one at the end is to insure that the last G code command is processed. Without a carriage return at the end of the line, the line is not processed. It's really easy to be staring at the G code wondering why the last line isn't being processed all because of a missing CR that you can't see.
    2932
    Quote Originally Posted by Ashish B View Post
    What Mitsubishi model?
    May 2009
    393
    Model - Mitsubhishi M64
    Communication software - HyperTerminal
    Thanks for your reply.
    May 2009
    393
    Hi Friends,
    Couldn't find any way to disable the output of " % " sign during DPRNT output.
    Thanks for your valueable responses.
    Ashish
    Sep 2010
    1230
    Ashish
    Hi Ashish,
    From the machine control perspective, no. However, some communication software allow characters to be filtered out as they are received. Check you software to see if this feature is available.
    Regards,
    Bill
    May 2009
    393
    Thanks for your response.
    Is there any such filtering option in HYPER TERMINAL Software ?
    Sep 2010
    1230
    Not that I'm aware of.
    Regards,
    Bill
    May 2009
    393
    Thanks Bill, for your wonderful support.
  1. Help me avoid mistakes!
    By Joe Jones in forum Want To Buy...Need help!
    Last Post: 01-11-2015, 09:47 PM
  2. How do I avoid a part of the job?
    By Hoverflyer.mk2 in forum Mastercam
    Last Post: 09-18-2011, 05:40 PM
  3. Can I avoid G28?
    By Crashmaster in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2009, 03:59 PM
  4. Which would you choose/avoid?
    By mstrsig in forum Commercial CNC Wood Routers
    Last Post: 02-05-2008, 02:51 PM
  5. Avoid Prosoftstore
    By gwb in forum MetalWork Discussion
    Last Post: 02-15-2007, 06:27 PM
