587,514 active members*
2,984 visitors online*
Results 1 to 11 of 11
    Apr 2009
    16
    Cutting Carbon Fiber
    Guys,
    What is the best setup, or setup recommendation for cutting Carbon Fiber and G10? Cutting speed and depth per pass with a 1/8 end mill. Thank for any tips.
    Jason
    Aerial Photography New York San Francisco
    Aerial Photography - New York, New Jersey, San Francisco
    Jun 2011
    mine also the same question
    Centers
    Jun 2011
    try another cnc machine
    I advise you try water jet cutting, it is much better
    Feb 2009
    6028
    Water jet can feather some carbon fiber. We do a lot of it at work, but nothing that small so I can't help on speeds and feeds. I do know too fast and it melts cutters when dry. The cf dust is nasty, get everywhere and destroys equipment a lot faster than you would think. In the milling lathe, we cut it wet, and have a 18k dollar paper filter system with a 2 micron post filter.
    Jun 2011
    Quote Originally Posted by underthetire View Post
    I have cut a kind of fibre which is used to make bullet-proof jacket. And the performance is good. I think. No feather effect as you said.
    Oct 2007
    97
    The best thing we found is to use a PCB router bit. Diamond cut seems to work better on the carbon fiber. They are pretty cheap and last a decent amount of time as they are made for cutting composites (FR4).
    John Torrez
    Think & Tinker / PreciseBits
    Jun 2011
    Quote Originally Posted by TDA View Post
    How do you guarantee the kerf? It may be not ideal. And how thick can it cut?
    Jul 2005
    302
    Use only special bits for carbon fiber (or glass fiber),
    VHM - Fräser für CFK mit Diamantbeschichtung 3,175 mm | eBay
    VHM - Fräser für CFK mit Diamantbeschichtung 0,8 mm | eBay
    these ones just for view ... this guy sells very expensive the same you can buy ten or more time cheaper and as good as well
    They call very differently these bits everywhere around the world, different brands, some are better some are not so good, some are very brittle ... but anyway dont try with normal endmills for metals what are much more expensive and you blunt normal endmill in few seconds.
    I do run at 12k ... 24k RPM and only with coolant or just water,
    cheers,
    herbert
    Oct 2007
    97
    Quote Originally Posted by livemott View Post
    I'm not sure what you mean by guarantee the kerf. The kerf is determined by the size of the tool you use. Each manufacturer has a different spec for tolerance. As an example our spec is +0, -0.002 on diameter. The larger the tool is the deeper they cut. You can usually go about .25" (6.35mm) with a .0394" (1mm) cutter.
    Quote Originally Posted by Herbertkabi View Post
    cheers,
    herbert
    Those are diamond cut router bits. You will see differences in the depth of the cross grind, gash of the tip of the tool, carbide used, ect. But that is the core design of that tool.
    John Torrez
    May 2009
    5
    I cut carbon everyday. I use the diamond cut bits which give a perfect edge and need no secondary clean up work. Cuts are dry. Just use an air supply to clear the kerf which will prolong the bit life. Make sure to get a good dust collection system which picks up everything right at the cut site.
    The way the carbon is made plays a big part in how the edge will look when cut. If you are getting frays then you will have to change up the way you make your carbon.
    Nov 2011
    when you are cutting cf, which is the speed per second you use?
    For instance, the 1mm diamond cutter, in 2mm carbon fiber, at 10k rpm, what speed per second can it cut?
  1. Cutting Carbon Fiber
    By TazChris in forum Composites, Exotic Metals etc
    Last Post: 12-20-2012, 02:44 PM
  2. Cutting molded carbon fiber
    By alec in forum Composites, Exotic Metals etc
    Last Post: 02-09-2008, 01:40 AM
  3. Has anyone tried cutting Carbon Fiber?
    By A+ Machining in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-27-2007, 07:17 PM
  4. Carbon fiber cnc cutting
    By BFcarbon in forum Hobby Discussion
    Last Post: 03-02-2006, 03:31 AM
