588,288 active members*
5,167 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > machining an open pocket
Results 1 to 5 of 5
    Nov 2010
    How do you machine a pocket with 1 or 2 edges open in bobcad v23?
    I have played around an the best I can come up with is extending the part geometry by the diameter of the cutter at the openings
    Feb 2007
    505
    Cool
    Quote Originally Posted by winaa View Post
    Why dont you use line join to close the geometry temporarily.
    Posting your file should bring more solutions.
    oups!3d files I guess.
    Oct 2006
    173
    Currently extending the part is correct , it is the only way.
    Nov 2010
    Sorted
    For those of you that have read this thread and are wanting to know how to machine an open pocket I have found an easy solution.
    After a bit of web searching and watching the training video's I found the easiest way to do open pockets is with High Speed Milling. Just change the open side's of the pocket to a dashed line and Bobcad will automatically know that this is an open edge and the tool can pass through the dashed line.
    Very cool it works well.
    Apr 2009
    3376
    High speed pocketing,which I believe is not offered anymore.But yes,that is the best way to do open pocketing if you have that option.
  1. Machining a pocket in a casting
    By DIFF OVER in forum BobCad-Cam
    Last Post: 11-23-2010, 09:43 PM
  2. open pocket
    By camtd in forum Mastercam
    Last Post: 08-07-2007, 08:24 PM
  3. A machining pocket guide that uses real values.
    By bin95.com in forum News Announcements
    Last Post: 11-16-2006, 02:41 PM
  4. Open Pocket
    By camtd in forum EdgeCam
    Last Post: 10-23-2006, 07:09 PM
  5. Pocket machining question
    By Pat in forum MetalWork Discussion
    Last Post: 06-27-2005, 06:43 PM
