587,300 active members*
3,316 visitors online*
Results 1 to 2 of 2
    Nov 2007
    68
    X axis vibrztion
    Dear All
    We have a machining center with Fanuc 0imc controller, the problem is :
    When we make zero return for X axis, some vibration happens at the end of the stroke (when the X axis reach its zero position).
    This strange vibration happens in handle mode and ZRN and all modes.
    The bearing and backlash are ok.
    what shall be the reason for this problem
    Nov 2007
    68
    i think the vibration is coming from motor & coupling side.
    any help please !!!
  1. a problem with slaved A-axis moving properly relative to Y-axis
    By zool in forum Mach Software (ArtSoft software)
    Last Post: 07-06-2011, 03:45 AM
  2. X axis works fine but Y axis direction is erratic
    By swampbud1 in forum DIY CNC Router Table Machines
    Last Post: 12-07-2010, 12:28 AM
  3. Grinding and unexpected axis movement if rapiding 2 axis
    By DarkSabre in forum Taig Mills / Lathes
    Last Post: 03-26-2010, 05:37 AM
  4. Compare Catia and MCX2 for multi axis lathe/4 axis mill
    By bob1112 in forum Uncategorised CAM Discussion
    Last Post: 10-11-2008, 01:15 AM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
