588,484 active members*
5,068 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Helical Interpolation
Results 1 to 7 of 7
    Jul 2010
    174
    Here's a chunk of code that helically interpolates in incremental mode in a sub program. I like doing it this way on the fly:
    Code:
    :1
    G17G40G80
    T1
    M100
    (.312 END MILL)
    G90G0G54X0.Y.625
    S3500M3
    G43Z1.H1T2
    G1Z.007F50.
    M8
    G41X-.1295D1F15. (0.563(.571) DIA.)
    M98P2L46
    G40G0X.1295
    G90G0Z1.
    M101
    G28Y0.
    M30
    :2 (DEPTH 0.315)
    G91
    G3I.1295Z-.007
    M99
    It gives me a nice clean helix consisting of nothing more than Z steps, like this (NCPlot screen capture):
    How can I generate a nice clean helix like this in GibbsCAM using the Roughing function. All the options seem to want to switch back to absolute mode and insert a circular interpolation on every step, or something similarly complicated. I end up with helixes that looks like this (Auto, Helix end at SP):
    Thats some weird looking code. I just want a simple helix.
    Aug 2006
    142
    Make a simple circular path with the "Z" step you want then go to Plug-Ins>HSM>Z-Ramp Contour. You will get one lead-in and one lead out and zramp the rest.
    Jul 2010
    174
    Thats it. Perfect. Thanks
    Jun 2003
    513
    Helix Bore plugin.
    Dec 2010
    If I'm boring a large hole, say 4 inches, with a small endmill, 1/4 inch, if I used this helix bore there will be a large chunk of metal left in the bore that will intefere with cutting.
    Is there a way to have it start in the middle of the circle and helix out, same functionality as is provided for the G12 and G13 commands on Haas machines.
    Here's a video of the operation.
    [ame=http://www.youtube.com/watch?v=RedRvocsJvo]HAAS G12/G13 - YouTube[/ame]
    Jun 2003
    513
    Quote Originally Posted by canyon289 View Post
    The Helix Bore plugin is for making helical bores, not pocketing.
    The standard Roughing process lets you make helical entries with 5 options on placement, three of them with user defined diameters, and 4 options on how to engage the material.
    In addition to user defined helical entries, the Advance 3D Pocketing has more options for toolpath control.
    Nov 2009
    5
    oops, delete me.
  1. helical interpolation 15m
    By Goran P. in forum Fanuc
    Last Post: 01-21-2020, 10:05 AM
  2. Helical Interpolation
    By jjproto in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-10-2011, 10:59 PM
  3. helical interpolation
    By Montabelli in forum Mastercam
    Last Post: 04-11-2010, 03:34 AM
  4. MV 35/40 Helical Interpolation
    By Millem in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2007, 03:54 PM
  5. Helical Interpolation
    By dbcoop11 in forum Bridgeport / Hardinge Mills
    Last Post: 12-31-2004, 05:15 PM
