588,333 active members*
4,316 visitors online*
Results 1 to 3 of 3
    Jan 2006
    333
    probing an angled part
    Hey guys, I have a question for those with a probe...
    I am making some insert toolholders for my lathe. I am making them
    5deg X 5deg. Setting X0Y0Z0 with the probe is interesting because because of the angles the probe slides (in the Z direction) for X and Y I can use a wiggler but any suggestions for finding Z0 with the probe? The angle is 5 degrees on the top of the part.
    Mark
    Apr 2005
    713
    Probe your vice or fixture anywhere it's flat, then measure from there to a known point on your part using an indicator and the operator screen in hand jog mode. Adjust the Z offset using that number.
    Or just probe the part where ever you think you need to, then bring a tool down to Z.01 and dial it down slowly until it touches. Any difference is what you need to adjust the Z offset by.
    I know what you're seeing with the probe stylus skidding on the surface, but that's only for the first touch. The second touch shouldn't do it at all, and should be very accurate.
    Jan 2006
    333
    Thanks a lot. You are right, the probe skidded and then I hit reset for fear of breaking the stylis. I will try it again and see what happens after the first touch.
    Mark
  1. problem with angled cut
    By da_Rayman in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-22-2012, 09:28 AM
  2. Part Probing systems for CNC routers?
    By mafitch7479 in forum Commercial CNC Wood Routers
    Last Post: 06-14-2011, 07:25 PM
  3. Angled head
    By Alirumba in forum EdgeCam
    Last Post: 06-28-2009, 06:23 PM
  4. Engraving on angled surface around a part?
    By Blink in forum Uncategorised CAM Discussion
    Last Post: 02-22-2008, 02:16 PM
  5. horn pin (angled pin)
    By spider in forum Moldmaking
    Last Post: 09-29-2007, 01:37 PM
