587,128 active members*
3,043 visitors online*
Results 1 to 5 of 5
    May 2009
    393
    Post How to eliminate backlash ?
    On my CNC Mill, I am experiencing positioning errors. I think that there are some BACKLASH issues associated with it.
    I searched CNCZONE.COM for posts related to backlash. I really admire that all the posts are wonderful and really provide a indepth understanding of the BACKLASH. Also i can see some posts mentioning about the assembling the nut over the lead screw.
    But to be frank, I can't understand those assembling issues and cannot do nut adjustment. I cannot do that because i am a root level operator.
    Hence i request that please guide me to a simple solution to get rid of the backlash problems ?
    Ashish
    Jan 2010
    Talking Back Lash
    It is helpful if you use a test indicator to measure how much backlash you have in each axis, in each direction. If it is minor, you can just make sure to keep the ballsrew going in the same direction each time you position the tool to the workpiece. In our situation, our horizontal mill has a tool changer and it has to go down in " Y " axis, ( minus ) and over in " X " axis ( minus ) after each tool change to position to the work piece. If we have critical positions to hold, we just add a jog motion Y +, X +, then Y -, X -, to keep the ballscrew alway positioning from the same direction to take up any backlash.
    I know this is not a fixall but it helps if your backlash problem is of a small amount.
    Dec 2003
    24223
    Quote Originally Posted by Ashish B View Post
    Ashish[/COLOR][/COLOR]
    The details I made in your other post should help.
    You have to identify where the backlash is of course, with a direct driven B.S. there is only a couple of places where it can be, either in the coupling or the B.S. nut, many precision B.S.'s have either preloaded nuts that self tension the pre-load, or have an adjustable pre-load.
    If you do not have pre-loaded nut on the B.S., this could be where your B.L. is.
    Al.
    Albert E.
    May 2009
    393
    Yes, I will check in that style & let you know asap.
    Ashish
    May 2009
    393
    I performed BACKLASH TRIALS as per your instructions. It goes as follows -
    In X axis -
    I touched a part by using plunger dial & jogged untill dial showed 0 reading.
    Than i retracted back by 0.04 mm, but the dial pointer was retracted by 0.01 mm only.
    So, is it a backlash error of 0.030 mm ?
    In Y axis -
    Than i retracted back by 0.001mm, but the dial pointer was retracted by 0.020 mm...
    So, is it a wrong backlash setting?
    Also, i checked backlash error on my CNC turning (which is brand new...i purchased it on 20th august)... But backlash error was also in existence on that machine..
    How to deal with backlash & whats the correct setting ?
    Ashish
  1. Options to eliminate backlash?
    By cnczoner in forum Linear and Rotary Motion
    Last Post: 01-31-2013, 06:44 PM
  2. How to eliminate manual cutting of rubber stamps
    By RRSS79 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-18-2011, 08:29 AM
  3. How to eliminate the corrosive effects when machining TZM ???
    By Hypermold in forum Material Machining Solutions
    Last Post: 08-12-2010, 02:18 PM
  4. eliminate start and stop of spindle for short program?
    By endgrainguy in forum G-Code Programing
    Last Post: 06-09-2009, 03:06 AM
  5. Methods to eliminate chatter on long thin piece
    By pmurdock in forum Haas Lathes
    Last Post: 03-18-2009, 08:25 PM
