587,777 active members*
2,894 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Jet Mill Drill JMD-18PFN what do you think ?
Results 1 to 2 of 2
    Aug 2003
    I read about grizzly, Harbor Freight, Enco, other mill drills, I have not read anything here mentioned about a Jet mill drill model
    JMD-18PFN.
    What do you think of the Jet mill drill ?
    How does it stack up against the others ?
    Feb 2005
    750
    There all the same! If it looks like the same design, then it probably is the same. Some might be a little better assembled, a little cleaner, better adjusted and QC'd, but they are all made from the same components. Ive only seen pictures of the Jet Mill, but its essentially the RF 31. They also sell the 9x20 lathe (at 1500.00). I have a wood shaper from Grizzly that they sell a version of. Jets a great company for service and warranty (2 Years), They may have an american motor in thiers, but your gonna pay for the pretty paint job! My Harbor Freight 33686 was so sloppily adjusted that it was essentially unusable the way it came shipped, but it is the cheapest of the bunch. After re adjusting all the moving parts it is as good as any of the more expensive ones. I use mine everyday and I am blown away at how fast and clean the thing cuts. Today I was cutting a sword blank out of CRS with a 3/4 end mill cutting the full blade profile and chunks of metal were flying 7-8 feet off the spindle with not even a hint of hesitation or vibration. The thing screams through metal!
    Halfnutz
  1. My mill has finally arrived! (Proxxon FF400)
    By mutionu in forum Uncategorised MetalWorking Machines
    Last Post: 04-29-2013, 01:40 PM
  2. Tree Mill conversion Questions
    By Flyinfool in forum Uncategorised MetalWorking Machines
    Last Post: 05-28-2005, 04:37 AM
  3. Eagle Mill drill conversion
    By Georgie in forum Vertical Mill, Lathe Project Log
    Last Post: 02-24-2005, 02:12 AM
  4. Pictures of My Lathe & CNC MILL
    By studysession in forum Uncategorised MetalWorking Machines
    Last Post: 01-04-2005, 11:07 PM
  5. jet Mill Drill JMD-18PFN , What do you think ?
    By rudolf in forum Uncategorised MetalWorking Machines
    Last Post: 08-08-2003, 01:36 AM
