Hi Guys,
Leaning Gibbscam and I've run into a problem I cant solve using the manual...
Im cutting a test program of a hemisphere (30mm in dia) and the cut surface off the mill is faceted. The part surface in gibbs is very smooth (imported parasolid file out of Inventor) but the facets show up in the cut part render when the stock is cut.
Im running a surface flow cut as the finishing pass after a contour rough, Im sure there is a global tolerance setting that im missing, but every tolerance box I change ends up with the same result..
Any advice?
regards,
Scott
