587,307 active members*
3,719 visitors online*
Thread: solid models
Results 1 to 3 of 3
    May 2007
    15
    solid models
    I am havig trouble with solid models imported fromsolidworks.I've tried .sat,iges,sldprt,,,with no difference.When loaded I can't do wireframe machining,or solid machining.What is best format for importing to esprit?
    thanks
    Tom
    p.s. it's esprit wire 2009
    May 2011
    Once you open your model and have it oriented the way you want it, select the model, right click and select copy. Use smash to extract wireframe and select the tolerance. You should get all of the wireframe data you need from there.
    Jun 2008
    39
    Another way of going about it, is after you click "file" "open" and you select the solid, click the options tab (lower left side of OPEN window. There you can set it to open as a solid, and wireframe.
  1. Solid Models of Machines?
    By behindpropeller in forum Haas Mills
    Last Post: 10-20-2011, 06:45 PM
  2. Editing Solid Models In Esprit
    By thebowman in forum Esprit
    Last Post: 01-24-2011, 01:19 AM
  3. Aligning solid models
    By cncstephen in forum Mastercam
    Last Post: 03-11-2010, 08:58 AM
  4. Fadal 15 solid models
    By robyc01 in forum Fadal
    Last Post: 11-19-2009, 04:18 PM
  5. Looking for solid models of a couple of threadforms
    By youngjim in forum Mechanical Calculations/Engineering Design
    Last Post: 09-20-2009, 10:49 AM
