Re: CNC Project !! AMA25LV (G0704) Mill !!!!!!!
![Quote](images/misc/quote_icon.png)
Originally Posted by
onocyclone
It's at 20. I think it's the ****ty couplers. They twist when they move slowly. I need to make some solid ones to eliminate this issue
![Smile](images/smilies/smile.png)
Solid couplers will buy you new headaches when shafts break. Oldham couplers are what you want to use.
As for the why your DTI readings are spot on: Think of it just like manual machining and backlash. Each approach you make from the same direction will be as accurate as the screw on the machine is. It's the reversal where the error shows up. So you approach, touch off the DTI to 0 and then you reverse away by 100mm. It's extremely likely that it moved LESS than 100mm away. First it has to take up all the slack in the screw, bearings, coupler, ect. Then it starts moving the table. Now it is at say 99.750mm away from your block but you can't see that. So now you reverse again and return to the block. Same thing, it has to take up all the slack, JUST LIKE YOU DID WHEN YOU FIRST APPROACHED, and head back to the block. Boom, the DTI lands exactly where it was before. Your position is repeatable but only in one direction.
Better backlash test is to approach and zero as you did before but now do incremental jogs of maybe 0.01mm the opposite direction, the number of jogs needed before the needle moves will tell you the amount of backlash you need to compensate for.
CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
