587,945 active members*
3,412 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seiki Repair / Service / Support
Page 9 of 10 78910
Results 161 to 180 of 185
  1. #161
    Dec 2009
    546
    Re: Hitachi Seiki Repair / Service / Support
    Hello!
    PM me your email and I can help, there are a few sets of batteries in that control, but could be other issue
  2. #162
    Quote Originally Posted by shas595 View Post
    Hello
    send me a PM with your contact info so I walk you through the process
    Hi. Need a help¡ In Hitachi Seiki VS50 SEICOS 18M, I'm getting D404.7 LS Tool unclamp alarm. I've checked signal status of all limit switch and sensors related to tool change. Kindly support.
  3. #163
    Dec 2009
    546
    Quote Originally Posted by mathalaikanna View Post
    Send me a PM with your email and I will assist
  4. #164
    Sorry I couldn't PM. Settings were compromised i guess. My mail
    [email protected]
  5. #165
    I upload Backup for HITACHI VK45II and VM40II in my home page.
    You can find it in Index of /~aike/docs
  6. #166
    May 2023
    HITACHI SEIKI VG45 STANDBY problema
    Buongiorno,
    Mi lampeggiavano i numeri sul monitor allora o spento e riacceso completamente il cnc, ma a questo punto cliccando il tasto standby mi rimane lampeggiante quinti fa partire la pompa idraulica ma non i motori/azionamenti sembra che ci sia un'interruzione, tentano di avviarsi ma dopo circa un secondo cadono( non ho allarmi) tranne quelli vecchi tipo controllo olio lubrificazione che non vanno via perchè non riesco a superare la fase di accensione potete aiutarmi grazie
    Su LADDER vedo un'interruzione
    sul parametro 380.6 cos'è questo parametro?
  7. #167
    Hi!
    Please write in English. Google show me bad translation from Italian.
  8. #168
    May 2023
    Hello. I can't open these files. Can you upload in another format? Thank you
  9. #169
    May 2023
    Quote Originally Posted by =aike= View Post
  10. #170
    Hello.
    We have Hitachi Seiki Vm 40II with Seicos 3 control. I just enabled the DNC and I would really appreciate it if somebody could let me know which parameter I should change to enable helical interpolation, spiral milling. It is an option and as far as I know one of the parameters higher than 9000 should be changed.
    Thank you.
    - - - Updated - - -
    Hello.
    Thank you.
  11. #171
    Jan 2024
    Hi all. Please tell me what to do, an error has appeared on the machine 1040 (8000) ASV1C alarm ram error.
  12. #172
    Dec 2023
    If you changed the main board, it is likely a software problem. Send me a PM with your email and I will contact you direct
    Hello shas595
    Thanks for your time. I hope you can help me
    I have the same problem (DIRECTORY BROKEN). It is a Hitachi lathe that lost parameters. We have the parameters printed. They were loaded manually.
    but in the end this broken directory alarm appears
    my email is [email protected]
  13. #173
    Dec 2009
    546
    Hello
    Send me a PM with your email and ill help, it wont let me send one to you
    Quote Originally Posted by JaniJenko View Post
    Hello.
    Thank you.
    - - - Updated - - -
    Hello.
    Thank you.
  14. #174
    Dec 2009
    546
    Alarm is usually due to SAMS2 card going bad. PM me your email for additional assistance
    Quote Originally Posted by DMus View Post
  15. #175
    Jan 2024
    Hi all. Please help someone who can, Hitachi Seiki HiCell 23B. Please share the machine parameters, my B axis is not displayed and the sub spindle is not controlled.
  16. #176
    Jul 2016
    6
    Hello. Please help. Hitachi Seiki HT20S2 with Seiki
    MULTI control. I am getting 3 alarms."ALARM 362
    Z-AXIS PG ERROR * SEE OPERATION MANUAL (6-1)".
    "ALARM 322 CMOS VACANT AREA ERROR".
    "ALARM 310 POWER FOR SERVO NOT SUPPLIED* RESET EMERG.
    THEN DEPRESS STANDBY.
    The STANDBY light is not lit after pushing RESET
    And then STANDBY.
    It looks like the Z-AXIS clutch is engaged and the
    Proximity switch above the clutch is red. That servo
    Motor does not appear to be engaged. Please help.
  17. #177
    Dec 2009
    546
    Quote Originally Posted by HAMMER1 View Post
    And then STANDBY.
    Hello!
    Is the servo drive on for the Z?
    It’s possible you lost some parameters due to power loss or weak battery. Parameter #6001 d3 is enable CMOS spare area check function. You can change it to a 0, reboot , turn off and change to a 1 and see if it clears. If not you might need to regenerate the control and renter all parameters.
    I would advise making a backup now before anything else
    John
  18. #178
    Jul 2016
    6
    Hello!
    John
    Thank you for the help John.
    There are 2 208VAC power supplies to both servo
    drives, a single phase and a 3 phase. The single
    phase is at the drives' terminals. The 3 phase is
    controlled by a contactor "MS-SV". THAT contactor is
    not energized as it is controlled by relay "SVMX".
    That relay is not energized and controlled by the
    LX-3 I/O board. So to answer your question the servo
    drive is NOT turned on, even though some LEDs on the
    drives are lit.
    Can I use one of the RS-232 ports to make a complete
    digital backup of the drive? What is the procedure to
    make the digital backup. In the the machine's record books I have found a couple paper backups of some of 6000
    thru 7082 parameters. I will have to do some comparison
    to see if they are the same and how they compare to what's in the machine control. Besides the parameters, what
    else do I need to be concerned of losing?
    Again, thank you for you help.
  19. #179
    Jul 2016
    6
    drives are lit.
    I have a paper backups of the parameters N6000 thru
    N7082. Are there more parameters than those? If so
    how do I get to them?
    Again, Thanks John
Page 9 of 10 78910
  1. Hitachi Seiki Service and Support!!!!!!!!1
    By Hitachi_man in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2024, 12:29 PM
  2. Hitachi Seiki Electronic Repair
    By controlsgadgets in forum News Announcements
    Last Post: 03-14-2022, 12:02 PM
  3. Hitachi Seiki Gearbox Repair
    By DPGE Rebuilds in forum News Announcements
    Last Post: 06-13-2006, 10:49 AM
  4. Hitachi Seiki Gearbox Repair
    By DPGE Rebuilds in forum MetalWork Discussion
