603,386 active members*
3,108 visitors online*
Page 10 of 12 89101112
Results 181 to 200 of 239
  1. #181
    15362
    A Big Happy & Prosperous New Year to everyone
    I hope this year gives me more time to work on this router build, & cool new projects that are in progress
    Mactec54
  2. #182
    I'm looking forward to next update. This is my favorite thread
  3. #183
    May 2010
    can't wait
    I'm looking forward to next update. Very nice build.
    Eric
  4. #184
    Jul 2006
    1256
    Hay Mactec do you need any more friends?R U the guy with the 20 ton injection machine in your garage?
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
  5. #185
    15362
    JanHenning
    ickee
    Thanks for your interest, I'm hoping to be back on this build soon
    lgalla
    I wish I did have a 20Ton injection molding machine it would help with the smaller parts, The injection molding machine I have is 60Ton
    Mactec54
  6. #186
    15362
    Today I machined the Yaxes Beam, so the Linear Rails could be mounted, a .100 deep slot was mill on both edges of the Beam then the Mounting Holes were Drill & tapped
    Attached Thumbnails Attached Thumbnails Beam Machined for Linear Rails-1.jpg
    Mactec54
  7. #187
    Mar 2011
    805
    Mectec54,
    Triangular cut out in the middle of the beam is to reduce the weight?
  8. #188
    Apr 2009
    266
    wow! looking great!
    dunno where you are but wanna move over to NJ?
    love to have neighbors like you!
    hahaha
  9. #189
    15362
    Cutting the Linear Rails to length was the next step
    Cutting the Linear Rails may seem hard to do fo the home hobby guy, but does not have to be, they can be cut with a Dremel using a cut-off wheel, or a chop saw, or any rotating spindle that you can mount a cut-off wheel on, Just remember cut-off wheels can shatter, so care must be taken when using cut-off wheels
    I do most of my cutting using a surface grinder, it's easy to mount a vice on the magnetic chuck, & cut away
    Photos show the Cut Rails with no heat discoloration to the rail, if you are cutting it right the Rail will only get hot to the touch
    After cutting the Rails, the Ends need to be Deburred, this needs to be done very well, if not the seals on the Linear Bearings will be damaged when assembled, this can be done with a diamond file & then smoothed with a Dremel or hand grinder Etc
    When deburring is finished it's a good idea to Demagnetize the rails, before Assembly
    Attached Thumbnails Attached Thumbnails Cutting the Linear Rails to Length-2.jpg   Linear Rail Cut-3.jpg   Linear Rail Ends Deburred-4.jpg   Linear Rails Demagnetized before  Assembly-5.jpg
    Mactec54
  10. #190
    15362
    kinghong1970
    I used to live in NJ, had a dreamy shack on Lake Mohawk, also lived in Princeton
    azam1959
    Yes to reduce a little weight, The Beam is machined on both sides the same
    Mactec54
  11. #191
    May 2010
    155
    You are going to make this a production eventually right...
    your machine is professional to the nth degree and well I'd hate to see it be a "one of" ...
    anyways great work as always looking forward to videos of it all in action
    From Dave!
  12. #192
    Apr 2009
    5516
    You're making everyone else's machines look bootleg...
  13. #193
    15362
    Thanks for you comments & surport
    restless1
    louieatienza
    Mactec54
  14. #194
    15362
    First the Linear railes were cleaned
    I then they were mounted to the Beam, This is now ready for the Y & Zaxes carrage
    Attached Thumbnails Attached Thumbnails Linear Rails Ready for mounting-6.jpg   Linear Rails Mounted on Beam-7.jpg
    Mactec54
  15. #195
    15362
    A little more progress,I have put the Y & Zaxes carriage onto the Linear Rails, it went into place very easy, & is smooth to move the carriage/slide from end to end
    The next parts to make will be for the Z axes, This axes will then be complete
    Attached Thumbnails Attached Thumbnails Yaxes Carrage Mounted on Beam-9.jpg   Yaxes Carrage Mounted on Beam-8.jpg
    Mactec54
  16. #196
    Apr 2009
    266
    mactec54,
    i dunno bro... if i had a machine like the one you're building... i'd be wondering whether to put this inside a glass display case or use it to cut something...
    my first..."Big Ape" CNCRP 2448 Build Log
  17. #197
    Feb 2011
    210
    Hi Mactac , did you have everything designed in 3D?
  18. #198
    15362
    kinghong1970
    Thanks for your comments & support
    To me it's just a machine, once it is anodized it will be easy to keep clean, a glass case
    that would be an enclosure to keep the chips inside
    Mactec54
  19. #199
    15362
    bonmotwang
    Mostly 2D drawings some parts I have done in 3D, I may do a 3D of when it is all complete
    Mactec54
  20. #200
    Dec 2010
    634
    Truly fantastic work!
    What's the T - shaped thingy on your Z-axis? I get that part of it is going to hold a bearing or something like that but I don't get what the part that goes under the beam is for.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
  1. Noob - Helping friend use CNC router.
    By RandEE in forum Controller Cards
    Last Post: 03-25-2019, 09:47 PM
  2. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
