588,533 active members*
8,948 visitors online*
Page 10 of 10 8910
Results 181 to 191 of 191
  1. #181
    Apr 2016
    18
    Re: New MODBUSEZ SetUp Plugin For UCCNC
    Hello I read your Modbusez post Dec 23 2020 I would be very very interested in your findings on the GT-Series I have one that demand to spin(lol) mine is a GT-7R5G-2, I am taken to your words if you can help me that whold be very greatfull.thank you in advance andyjack38
  2. #182
    Can i use this plugin in mach3?
  3. #183
    Can i use this plugin in mach3? I have yl620-a vfd
  4. #184
    No, it's for UCCNC only.
    Mach3 has a modbus plugin that will do the same thing.
  5. #185
    Care to share your setup? I am trying to get my Fuling DZB280 running, and I cannot find anything on it in regards to the Plugin Setup.
  6. #186
    Jun 2022
    did you manage to solve this problem ?
  7. #187
    Jun 2005
    11
    Dont know if anyone monitors this thread nowadays, I have a Fuling dbz300 which is running via modbusez. the issue is that when 10000rpm is commanded in mdi the spindle only spins at 7500rpm. this is across the range of rpm. If I want 24000rpm I have to input 36000into UCCNC.
    It seem like a multiplier or conversion factor within the Modbusez pluging. the VFD shows the correct rpm the spindle is turning at, IE 36000rpm UCCNC 24000 indicated at the vfd.
    Any Ideas anyone?
    other than tis issue modbusez works really well, Thanks for your effort Dan.
    Phil
  8. #188
    Jun 2005
    11
    sorry double post
    Phil
    tarnish1
  9. #189
    Apr 2023
    Hi Dan
    Awesome plugin ! Could you maybe share the source code?
    If not could you maybe make a new version with more fields "Amp Displays" to read more stuff from vfd like power, speed, amp, ......
  10. #190
    May 2021
    I have a huanyang hy02d223b vfd and i've been having trouble with hyplugin wannt to try this, but i have no idea how to setup the modbus setup. any help out there? I know its an old thread
    thanks
Page 10 of 10 8910
  1. PCB Autoleveler Plugin for UCCNC
    By cahit in forum UCCNC Control Software
    Last Post: 11-22-2019, 01:41 PM
  2. Uccnc - plugin creation - pendant
    By robertspark in forum UCCNC Control Software
    Last Post: 09-02-2017, 09:42 AM
  3. Waiting for VistaCNC plugin for UCCNC
    By iflyinverted in forum UCCNC Control Software
    Last Post: 05-25-2016, 04:20 AM
  4. UCCNC units and setup
    By skcncx in forum UCCNC Control Software
    Last Post: 12-30-2015, 04:46 PM
  5. SX-3 Mill Conversion, ESS Plugin Setup in Mach3
    By mrpackethead in forum X3/SX3/G0619/G0463
    Last Post: 02-04-2014, 10:43 AM
