Under heat lamps the steel probably got hotter than the main E/G batch.There was more air bubbles around the steel as the heat expanded the entrapped air.One should not rely on the thick E/G mix to totally wet the steel.The steel and perhaps the entire mold should be pre wetted with neet resin first giving a better bond and perhaps a sporty finish.
Larry
