Originally Posted by
peteeng
Evening all you Sages and Neophytes - Today I got the gantry finished and trial fitted. I then set the primary wall rail, (can't say master and slave anymore) its coming along very nicely. When I designed the drives for Frankie the supplied dwgs for the motor mounts/bearings was a bit vague so I didn't order the ballscrews. I was also told the alloy ones where the same as the steel ones. Well they are longer so the ballscrew end details will be different. So I'm glad to have waited to see these in the flesh. Tomorrow I can set the secondary wall rail then move onto the gantry rails. These will need to be cut as the drive nut screws ended up interfering... then draw up the ballscrews and get them on order. I'm going to order an 800W water cooled spindle for Frankie... All the big hurdles have been jumped now, just need to do lots of assembling. Peter
