Thats the one i want....main screen....i need to know if you are able to increase the value on the screen by using this external pot you connected up
That hz value must go up and down when you turn the external pot that you connected....does it?
turn the external pot and see if this value changes please
okay we getting somewhere now....you sure you connected the pot correctly?
Those four dip switches on the drive....fourth one must be down/off
Wires ok?
Sent from my SM-G935F using Tapatalk
Please make sure these are set
3-00[0]
3-10[0.00]
3-12[0]
3-14[0]
3-15[1]
3-16[1]
3-17[1]
3-18[0]
okay your pot is connected properly...just checking
stop the drive.....set the parameter values i gave you....then turn the power off to the drive till its fully shut down. power up again then make sure you in auto then try and change the Hz value in main screen again with the ext pot...thanks
another parameter 6-01[0]
I have to go through and check if some parameters were changed...
6-10[0.07V]
6-11[10V]
6-14[0]
6-15[50]
6-19[0]
6-80[0] we will disable the onboard pot for now
This has to work....if it doesn't then i have one more option
Have you done all those parameters?
