588,457 active members*
5,146 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNC Project !! AMA25LV (G0704) Mill !!!!!!!
Page 11 of 28 91011121321
Results 201 to 220 of 552
  1. #201
    Sep 2014
    286
    Re: CNC Project !! AMA25LV (G0704) Mill !!!!!!!
    Yes I've tested it when you reverse the direction. Spot on. Maybe 0.00001 out. It goes slightly past zero sometimes .
  2. #202
    Dec 2009
    1416
    The best thing you can do is post a video of your process on determining backlash so it is clear what is and is not going on and what and how you've tested.. If you are able to reverse with complete perfection then your part should be on-dimension within the limits of the machine's rigidity, tool flex, and real tool dimensions. That would lead me to suspect the program.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  3. #203
    Sep 2014
    286
    I'll have a look at it in the next few days,
  4. #204
    Sep 2014
    286
    What is the best accuracy that these machines can achieve ? With my ball screws ? (C7) 0.005mm ?
  5. #205
    Jan 2008
    1543
    Haha, push on the spindle sideways lightly and it'll move 10 times that.
  6. #206
    Sep 2014
    286
    Really !!
  7. #207
    Feb 2006
    7063
    On a benchtop machine, you're lucky if you get +/-0.003" true accuracy when actually cutting metal. The machine itself will move and flex quite a bit. The more aggressive the cut, the more error you'll see. A "static" test, measuring move distance while "air-cutting" is fine for confirming axis scaling and backlash, but tells you nothing at all about the true dynamic performance.
    Regards,
    Ray L.
  8. #208
    Dec 2009
    1416
    I'll second that. There are two accuracy expectations. There is what the machine can do with an empty table which ought to be very close to whatever the screws are capable of giving you plus any 'sticktion' error from the dovetails not immediately moving in tiny increments. That is interesting as Ray said for getting the axis setup, testing large arcs, and getting backlash adjusted and all. When it comes time to cut metal the machine is going to flex and there will be way more error than that static test would indicate. Even the tool itself will flex in a heavy cut.
    That's where the use of roughing clearance and light finish passes do wonders. I can generally feel confident to promise +/- 0.0025" if I don't want to do any special setup or compensation. I can do better if I run a test or two and adjust the code to compensate for the results. Then I've been able to run small batches in the center of the table and get +/- 0.00075" on the X/Y. Z is always my most difficult to manage. Heat & spindle growth, touch-off accuracy, and accurate measurement of the tool length all make that a harder prospect for me to get better than +/-0.003" with.
  9. #209
    Sep 2014
    286
    Still not bad what is THE BEST couplers to buy then. No messing now
  10. #210
    Dec 2009
    1416
    Tough to beat Oldham couplers. Reliable, no backlash, simple, and tolerate massive alignment errors with no stress. They are even easy to make.
  11. #211
    Sep 2014
    286
    I can't see that if I made some solid couplers they would break the shafts. It would completely eliminate backlash as there is nothing that can move.
    If I made them with 2 grub screws then it will be solid
  12. #212
    Sep 2014
    286
    The motors should stalk before any braking occurs. If you crash it.
  13. #213
    Feb 2006
    7063
    If the two shafts are not aligned absolutely perfectly - exactly on-center, and exactly parallel - one, or both, of them WILL eventually fatigue and break. It may take a few weeks, it may take a year, but it will happen. The chances of having them aligned perfectly enough to prevent this is pretty close to zero.
    Regards,
    Ray L.
  14. #214
    Jun 2004
    6618
    I snapped one off myself this way. Since then I have replaced all my couplers with Oldhams.
    Lee
  15. #215
    Aug 2014
    52
    Onocyclone, your inbox is full so I couldn't send a PM
  16. #216
    Sep 2014
    286
    Try that mate.
  17. #217
    Sep 2014
    286
    Ive been messing with the machine again today, Ive re calibrated the machine and found that the head was not perfectly trammed. I need to correct this first. Ive been using a DTI to calibrate the machine and converted the imperial units on the DTI to mm. I got it so it was reasonably good but i then used a metric digital vernier scale and it shown it was extremely out. Like 0.75mm. I then calibrated the machine to the vernier scale and have got it to within 0.01-0.025mm.
    Im going to purchase a higher accuracy digital indicator before i recalibrate it again.
    Next thing I'm going to do is make some solid couplers and see if they will fix the back lash issue.
    One point i must add is i tested the rigidity of the machine and i forced the table and it moved the indicator around 0.0005". Is this acceptable ?
    Ive also messed with the velocity so i have got 800mm/Min in X
    600 in Y
    800 in Z
    Much faster than before Haha, ill have to be more careful now, before i could go for a cup of coffee before it reached where i told it to go
  18. #218
    Nov 2009
    4415
    Go ahead and start the thread, "why is the shaft broken"? At least you are consistent on ignoring good advice.
    A lazy man does it twice.
  19. #219
    May 2008
    1185
    If thy don't break the real problem is the vibration from the steppers making the ball screw ring.
    youtube videos of the G0704 under the name arizonavideo99
  20. #220
    Sep 2014
    286
    Ok as everyone is suggesting i don't use solid couplers i will get these Oldham Couplers. I didn't mean to disregard peoples experience.
    Where is the best place to get these couplers in the uk ?
    My Ball screw ends are 3/8" ( 9.52mm )
    Ive found that i can only get 8mm-12mm.
    My Z motor has a 14mm shaft but can't find an oldham coupler this size ??
    BG19-T | Ondrives
    Cheers,
    Olly
  1. Yay! "Project Cecil" G0704 build has begun!
    By TroyO in forum Benchtop Machines
    Last Post: 03-31-2015, 09:29 PM
  2. Let's call this the Turnkey Project - G0704
    By bogiestl in forum Benchtop Machines
    Last Post: 01-30-2012, 08:11 AM
  3. g0704 - conversion project
    By dsdmax in forum Benchtop Machines
    Last Post: 03-02-2011, 04:03 AM
  4. g0704 - first mill - questions ....
    Last Post: 03-28-2010, 09:32 PM
  5. CNC milling machine project, Weiss WMD25 / Amadeal AMA25LV
    By carl0s in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2010, 12:47 AM
