603,365 active members*
3,566 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Ezilathe, a useful aid to lathe programming.
Page 11 of 11 91011
Results 201 to 213 of 213
Hybrid View
    Nov 2007
    981
    Re: Ezilathe, a useful aid to lathe programming.
    Forgive me Stu, while I've never had an issue finding the new download before, for some reason I do not see your new version? I also do not see the "Downloads/Others" section so maybe I don't have access to it? As always, thank you for your efforts!
    Dave
    Dave->..
    Apr 2009
    127
    Dave
    Sorry, Stuffed up. It should read Downloads/Post Files. The new Ezilathe is at the end of page 2.
    Nov 2007
    981
    ahhhhhh.......got it, thank you sir!
    Dave->..
    Jan 2004
    236
    Stutank,
    v1.8 is working great. Thank you!
    Mike...
    Apr 2009
    127
    I have just managed to upload a compressed version of the Manual in PDF Format. - Still looks good
    in Downloads\Post Files - second page.
    As per std procedure after uploading a new version, I find a couple of issues (inc. Prompt box for tool selection stopped working as the most visible).
    This + a few things to do in "Grooving" will be fixed soon as a beta upload.
    Oct 2023
    Quote Originally Posted by Dragon8 View Post
    I've only been on this forum for a week now, and already getting good value.
    Hiding in the "Downloads/Post File" section of tis forum is a program for download called "Ezilathe".Instaaero Apk
    I am saving hours using this program to generate / test Gcode for my CNC lathe. It may not be a full blown CAM program, but it will put a toolpath around a dxf file as you direct, quick and easy (including all the roughing cuts). With a little time setting up your tool library it will accurately display the finished profile for acceptance or modification as required.
    Check it out.
    yeah, Ezilathe is a useful aid to lathe programming, I also have one to use.
    Nov 2020
    35
    Hi stutank,
    Are you planning to release an updated version of the V1.8 with the bug fixes soon ?
    Apr 2009
    127
    Rengan77
    Not had much time recently, partially fixed the bugs in grooving, but no other bugs reported. Hardly worth uploading at present.
    Nov 2020
    35
    Thank you Stutank for the reply. I shall wait for your upload.
    Cheers
    - - - Updated - - -
    Cheers
    Apr 2009
    127
    Hoping to get Back to Ezilathe in the near future. A few bugs, and hopefully finish the Cad4Lathe section.
    Nov 2007
    981
    Quote Originally Posted by Stutank View Post
    Thanks Stu!
    Dave->..
Page 11 of 11 91011
  1. Lathe programming
    By mcm1961 in forum Haas Lathes
    Last Post: 08-20-2021, 02:35 PM
  2. Cnc Lathe Programming
    By millmonkey1 in forum Employment Opportunity
    Last Post: 02-04-2011, 01:17 PM
  3. Programming a bar puller in X2 on a lathe
    By bob1112 in forum Mastercam
    Last Post: 01-06-2009, 05:05 PM
  4. lathe programming learning ?
    By pit202 in forum Haas Lathes
    Last Post: 11-23-2007, 02:41 PM
