588,201 active members*
4,799 visitors online*
Thread: Hoss's G0704
Page 111 of 344 1161101109110111112113121161211
Results 2,201 to 2,220 of 6871
  1. #2201
    Thanks AM I'll try and get a video posted later today/tonight.
    I need to use the 4th to finish a part so I'll have to indicate it in anyway.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  2. #2202
    Apr 2004
    20
    Spindle Bearing
    Hoss,
    Are you using just one (1) 7007 ac lower bearing? It looks like your retaining ring only has a couple of threads engaged. I've been thinking about milling the quill sleeve 6 to 7 mm to enable the use of two (2) lower bearings.
    Keep up the great work Hoss, I'm looking forward to your next DVD!
  3. #2203
    Hey Lundervold,
    Yes just a single lower AC bearing.
    My dust cover seems thicker than ones I've seen on later models and/or the threads
    could have been compromised during one of the many times it was worked over during
    all the belt drive tests and such.
    It's just a dust cover though.
    Hoss
  4. #2204
    Apr 2004
    20
    Thanks Hoss,
    Just changed to "cncmoose".
    I'm modeling the quill sleeve to see if there will be enough strength "meat" after milling 6 or 7 mm to allow the use of two (2) bearings.
    Besides, I have 2 quill sleeves one stock and one to experiment with.
  5. #2205
    That depth might be enough.
    I experimented with double lowers but didn't take it further.
    A single AC has a dynamic load around 4000 lbs. so I left it at that.
    May as well try though if you already have a spare quill sleeve to experiment with.
    Hoss
    [ame=http://www.youtube.com/watch?v=n8rbvnvhXoI&feature=channel_video_title]G0704 Double Spindle Bearing Experiment.wmv - YouTube[/ame]
  6. #2206
    Feb 2010
    3447
    It would be nice to see a 4th axis attachment that could be expanded upon to make a 5th axis without having to buy a completely different setup. I think that's what you have in store for your new rotary table?
  7. #2207
    Well if you don't want to tilt the head for the 5th or use a rotary table on a trunnion as a 5th
    another option would be to add a powered tilt to the rotary.
    Not on my project list though.
    Hoss
  8. #2208
    Apr 2004
    20
    Thanks Hoss,
    Your experimentation is an inspiration to all of us.
  9. #2209
    Apr 2004
    20
    Sorry, double post.
  10. #2210
    Quote Originally Posted by amyers View Post
    Sweet 4th axis Hoss, how do you center a part on that though with the 4 jaw and get
    it concentric with the rotary too?
    Thanks, AM
    Here ya go.
    Hoss
    [ame=http://www.youtube.com/watch?v=eZ3aT54Penw]G0704 4th Axis Indicating - YouTube[/ame]
  11. #2211
    Jun 2011
    695
    Quote Originally Posted by Hans_G View Post
    Speaking of that, when it comes to making chips, I never seem to have the right stock on hand. I've started to buy extra stock now whenever I order what I really need for the project at hand. Maybe my collection just isn't big enough yet to reach that critical mass.
    Do you have a large amount of various pieces on hand? If so, did you just collect them over time as leftovers from the many projects you finish? Any recommendations for building up a small stockpile? Variety packs, or just put a big order together, or ????
    Thanks.
    I usually order my cut pieces from Speedy Metals and as much as I try not to I always click on the "fire sale" section and start clicking away. I usually end spending more on the misc. pieces then I went there for. Nice thing they are usually odd ball size and priced right...great for building inventory.
    I have some coming tomorrow!
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  12. #2212
    Quote Originally Posted by FannBlade View Post
    You and me both.
    Hoss
  13. #2213
    Jun 2004
    18
    Thanks Hoss for the great info here and answering my questions through email. I've been a long time lurker here on CNCZone. I ordered my very first mill (G0704) and cant wait to start learning how to use it. Once I get the machine, I'll be getting your dvd to convert it to CNC.
    Grizzly said they're getting a shipment in on November 27 in the washington warehouse, I have a feeling I wont be getting one from that shipment. Let's see how long it'll take to get one.
  14. #2214
    Hey Trike,
    Thanks, glad to help the goodguys.
    You probably have a good chance of getting one, they are caught up with backorders mostly,
    some folks even got one still in stock at the last shipment and had it within a week.
    Good luck, Hoss
  15. #2215
    Jun 2004
    18
    I hope so, that will be an awesome early Christmas gift to myself.
  16. #2216
    Best of luck, hope Santa comes thru.
    Hoss
  17. #2217
    Aug 2011
    57
    Hoss, I'm slowly making progress on my G0704 following many of your modifications.
    I was wondering how far in your tapered gibs are. My X & Y are almost at their max depth. I will note that I used maybe 5 applications of 800 grit lapping compound. I just barely got the machining marks out of the ways. I've noticed too, that the gib angle does not seem to match very well with the dovetail - it seems to rub more at the top of the gib.
    If the gib does bottom out, what do you think of placing some shim stock behind it? I fear if the stock is too thin, it could want to roll up on itself during the adjustment of the gib.....just thinking outloud. Maybe I just need to order another set of gibs.
    Thanks for your input.
    -Mike
  18. #2218
    Hey Mike,
    Tooling marks aren't a bad thing actually, they help retain oil.
    If you've removed too much material you may need some new gibs strips, pics would help to compare with mine.
    As a last resort, a shim epoxied onto the gib strip may keep it in place (on the outer face that sees no movement)
    but it's likely only needs a very thin shim and probably won't hold up.
    If it needs a lot of shim, adding a thin piece of turcite to the inner face could be an option
    though not cheaper than new gib strips.
    Hoss
  19. #2219
    Jan 2010
    151
    Quote Originally Posted by hoss2006 View Post
    Awesome Hoss thanks I get it now you're the best.
    AM
  20. #2220
    Aug 2011
    57
    Hoss - I may try setting some .005in shim stock on the backside of the gib to make use of the existing gib.
    New gibs from Grizzly are only $8/each - so no huge loss if I need to purchase new ones.
    I know the taper is shallow, I'm just suprised that I could have removed so much material lapping the ways with 800 grit.
    My Y-axis way is beautiful. The gib is fairly tight and she moves as smooth as butter. My X-axis does seem to stick a little at the extremes, but managable. I'm sure the table will break in once I start running her too.
    My goal wasn't to remove all the machine marks, but to provide more surface contact for stability.
    Just as a point of reference for me, how deep are your gibs on your machine? Perhaps just reference the head of the forward gib screw...proud of casting, sitting even or down into the counterbore would be helpful.
    Thanks.
    -Mike
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
