588,414 active members*
5,131 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > Show how to build a CNC machine from the very beginning to the end
Page 112 of 184 1262102110111112113114122162
Results 2,221 to 2,240 of 3662
  1. #2221
    Jun 2007
    3891
    Re: Show how to build a CNC machine from the very beginning to the end
    datron machines start at about 60k. just sayin
    they are also light weight gantry routers build on a granite plate. not really in any way comparable to a cast iron mill of any size. they are build for speed and precision and not general purpose milling.
  2. #2222
    Jul 2004
    1424
    Quote Originally Posted by victorofga View Post
    FEA mainly works with sheetmetal structures likely a brige or similar..
    you can apply for cast iromn structures, but a real analysys will cost way more that customers of these machine ever could pay..
    Nice try. "Sheet metal structures likely a bridge?" huh? Never seen a "sheet metal" bridge. Most bridges I see are either made out of steel girders or are reinforced concrete. No sheet metal in sight.
    FEA excels for analysis of solid structures. How else do you think we design bridges, skyscrapers, and machinery in a modern world?
    Good FEA software is expensive, but that is not the same thing as saying "FEA is unaffordable". Fully functional educational versions of the software can be obtained (assuming you qualify) if you don't have access to the registered versions. While not as capable as some (more expensive) FEA software, the educational (also available to veterans) Solid Works edition includes the full Simulation Premium package, allowing anyone with some ME background and solid modeling capability to conduct basic FEA of structures.
    SOLIDWORKS Simulation Premium | SOLIDWORKS
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  3. #2223
    Jun 2010
    4262
    A friend of mine has a medium-to-larger machine which relies on floating the table on high-pressure hydraulics. There may be Rulon or Torlon faces in there as well. Costs a small fortune just to power the machine up! So where does that fit in with or against rails and so on these days?
    Cheers
    Roger
  4. #2224
    Jan 2007
    1795
    you can entering in details, however on the end it will comes back for this machine simply don't worth to looking for superprecision..
    riding on words... you can do it.. it just about you changing subject..
    with other words this machine made for folks who can afford only this.. and those folks are happy, don't complaining, but all others who never will buy one.. for all complainers, would nbe better just simply post a full documentation how yours would looking for this money..
    with dimensions with materials and everything..
    unless you show solution complaining itself on things... it lead no where..
  5. #2225
    Dec 2007
    2134
    this machine what visible built for general works, jobs these concerning just like one try to buying a wooden handle for showel, and checking with micrometer...
    what would you all say, if were see someone in the lowes measuring a showel handle with micrometer?
    Hit the nail on the head!
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  6. #2226
    Apr 2009
    5516
    Quote Originally Posted by tmarks11 View Post
    To what end? First of all, I'm prettysure you can't use the educational versionfor commercial use, that would violate the EULA. So yes for a small startup commercial grade FEA may not be feasible since the ROI we could take months, years. And really in the grand scheme of things knowing the precision of every other component and the stated accuracy is it really needed? Or, maybe if Defeng made 5000 of these a year, it may be worthwhile as far as optimizing materials usage. But in this case, for a 220lb. machine, aimed at a target market, it it way more than adequate.
    I can be sure of one thing - Grizzly, Sieg, LMS, as far as I know do NOT use FEA in their designs.
    - - - Updated - - -
    Quote Originally Posted by aarggh View Post
    cheers, Ian
    Aye aye...
  7. #2227
    Jun 2010
    4262
    Mind you, I found the FEA diagrams/results interesting and educational.
    Cheers
    Roger
  8. #2228
    Jul 2004
    1424
    Quote Originally Posted by louieatienza View Post
    Mostly because they are just copying or adapting machinery that was designed before computers were invented.... even down to the "M" on the milling machine base...
    My recommendation of educational software was aimed at the suggestion that a customer can dabble in FEA modeling of what he bought for the shear joy of it (which was what G59 said when he first showed his images of a wet noodle).
    However, you can get a SW seat with the simulation plug-in for $12k. Not talking $100k here to get analysis done for someone who has a commercial interest.
    Back OT, Defeng hasn't posted for 2.5 months. Hopefully things are still going well with him. I wonder how the Chinese Yuan devaluation is affecting him and his supply chain (Yes, I know it was "only" 4.4%)?
    Tim
  9. #2229
    Jun 2010
    4262
    Hi Tmarks
    Assume I am ignorant, and educate me: where does the 'M' come from - ie whose brand was it?
    Does that mean some people have been taking sand molds off an old machine? Dear me.
    Cheers
    Roger
  10. #2230
    Jun 2007
    3891
    the base package of solidworks at $4000 can do single object fea and is still very useful. there are many options that dont cost alot for fea. there is no reason to assume any chinese machine maker cant or wouldnt do fea on their original design machines.
  11. #2231
    Jul 2004
    1424
    Quote Originally Posted by RCaffin View Post
    The molded in "M" on the mill meant that the Meehanite process was used in making of the casting. It is a trademark that appeared on US mills.
    Meehanite: What's different about Meehanite
    Story goes that the entire casting was copied by a chinese manufacturer... complete with the "M".... but they didn't actually know what the M stood for and didn't actually employ the process. Might be an apocryphal story.
    Tim
  12. #2232
    Jun 2007
    3891
    Hi Tmarks
    Cheers
    Roger
    meehanite. its not so much a brand as a stamp of process adherence to get a specific iron composition.
    so yeah, some of the machines are just recast of existing ones, and may include the M even though they arent licensed. others are actually licensed. hard to know for sure.
    defengs machines are an entirely different procedure. just a basic "small part" grey iron casting. usually ht250 on small machines and ht350 on larger. they use the "lower" strength on small castings because its preferred in thinner castings. different irons develop strength based on cooling rate which is directly related to thickness. HT350 for example may become too hard and brittle on a 4-6mm thick wall, and ht250 wouldnt develop enough strength at 15-20mm..
  13. #2233
    Apr 2009
    5516
    Exactly. If you're making a copy of a proven design, why the need for FEA? For the joy of it? That's fine, but inot G59's case it was done to stick it to Mr.Handlewanker, and maybe discredit the work of Defeng. The reality is under its intended use and maybe more, this machine is not going to shake around like those blow up wavy things at the car wash. This is so obvious that it should not néedo mentioning, but soany hobbyists get consumed with FEA and not pay attention to other things (my aforementioned story of the guy who used FEA to design a mill of 2 x 4 lumber and sheet rock screws comes to mind.) If however we're designing the stiffest column using the least amount of material possible, thenot I can see the practicality.
    Haven't had the opportunity to contact Defeng lately, I wish him well and hope the recent events haven't hurt him much if at all.
  14. #2234
    Sep 2009
    1856
    around and around we go just let lou get his up and going then he will say`s how good or bad it is then go from there If you don`t like what Ian says just let it go
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  15. #2235
    Jan 2007
    599
    Quote Originally Posted by ihavenofish View Post
    the issue here is that the state of the art in cnc mechanicals hasnt changed much in nearly 40 years.
    If you are refere to the basic idea and operation then yes, i would agree. However if you look at the precision and speed that machining can be achieved then i'd say a lot has changed in the last 40 years....
  16. #2236
    Aug 2014
    889
    Posting my quick and dirty FEA results was indeed in part to shut someone who I think deserved it.
    To discredit the builder? Not my intention.
    But the results speak for themselves and yes they look grossly exaggerated but purposely done by all FEA softwares so the results can be better assessed. It doesn't mean you'll ever come close to that amount of distortion in reality.
    But really what matters is the resonance and at what Hz.
    In machine tools, such as this mill, Frequency in hertzs X 60 seconds X number of flutes of an end mill(for example), = at what rpm you will have reached the resonant frequency. That's the rpm you should stay away from.
    Surface finish is likely to suffer, however minute, if ignored.
    As for FEA being expensive, well it came with Inventor Pro 2014 that we use at work. $7900 we'll spent.
    Also, standard frequency range for designing machine tools is 0-2000Hz. This range covers 99.9% of the expected end use of the machine.
    Anyways, it's been an interesting read about sub micron and glass scales etc....
    I think though that's a bit too much for hobbyists. As stated earlier, it drives the price up considerably.
  17. #2237
    Sep 2009
    1856
    G59 you can use the ignore list.
    [SIGPIC][/SIGPIC]
  18. #2238
    Apr 2009
    5516
    Quote Originally Posted by G59 View Post
    I tend to wonder. Intentional or not. You came here and criticized this machine from the start. I'm sure Ian doesn't intend to be dead wrong about many things either. Again that FEA is useless if you just model it alone. The 30lb head acts as a ballast and mitigates some vibration and shortens the effective column length, even the ball bearings in the LM blocks act as dampers.
    Nowadays servos are becoming cheaper and entering the hobby level more, so it may not be too long before we see linear encoders for the home shop.
  19. #2239
    Jun 2007
    3891
    magnetic linear encoders can be had for $50 an axis in parts, repeatable resolution to half micron, true precision to 10-20 microns (not counting mechanical factors on the machine itself).
    i dont think any of our low costs controls make good use of them though.... yet.
  20. #2240
    Jun 2013
    1041
    Do you have a link to a supplier for the linear encoders? I have seen the ones from us digital and they are limited to 35.5 inches max length. If you know of something at the price you mentioned that can reach at least 120 inches or around 3 meters I'd love to hear about it.
    Ben
  1. Show us your machine stands
    By OHLEMANNR in forum Benchtop Machines
    Last Post: 05-05-2013, 03:19 AM
  2. a machine design (pics) from beginning to end
    By blurrycustoms in forum Vertical Mill, Lathe Project Log
    Last Post: 04-25-2013, 02:36 AM
  3. dry build or glue from the beginning?
    By Ezra in forum Joes CNC Model 2006
    Last Post: 10-29-2010, 04:44 AM
  4. Newcastle: Beginning of build plan
    By pippin88 in forum Australia, New Zealand Club House
    Last Post: 09-16-2010, 10:22 AM
  5. Beginning to build my Z-axis.
    By zonk2 in forum DIY CNC Router Table Machines
    Last Post: 12-23-2008, 06:17 AM
