It's great to have people's experience of vacuum degassing epoxy posted here .
However, could I make a plea to everyone doing so, to say what type of epoxy they were using.
If we're looking at low viscosity 100% epoxy, then I'd expect the degassing to occur without any "boiling". By which I mean that though there will be bubbles expanding and bursting quite dramatically, no component is lost that will affect the chemistry of the curing, nor any strength issues.
Obviuosly the value of the residual pressure you've dropped to is going to have an effect also. I don't know what the vapour pressure of typical epoxy resin components is at room temperature, but I'd be suprised if that would be a problem for most people, high vac pumps not being that common among the readers here, I suspect.
If we're looking at a low viscosity resin that contains a thinning agent like styrene monomer, then yes, it will boil off under vacuum at room temerature. Any other volatile components present will also come off, so possible effcts on the post cure strength etc. would be pretty unpredictable.
Regards to all,
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
