588,084 active members*
5,059 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Will build a Benchtop mill including Castings! Comments appreciated.
Page 12 of 15 21011121314
Results 221 to 240 of 300
  1. #221
    Nov 2005
    334
    Wizard: 1.- You are correct, this Spindle Housing casting is for a new project we are exploring.
    Could possibly be a universal Lathe or Mill thingie!
    2.- Usually anything resembling mass production in sand casting is match plate.
    If you look at the 1st page of this thread you will note the runners were actually
    added to “my” match plate by the foundry.
    The castings were hollow & required cores!
    See my Pattern making Guide post #116, this thread
    Post #120 shows some of our Patterns, Castings & where they were used.
    3. 4 or 5 foundries around here, most grandfathered in, however no new ones!
    Fann Blade: Looked at your Hurco retrofit thread – Keep up the good work!
    A Lot of smart guys over there too….very helpful when you get in a bind!
    I’ve retrofitted a Bridgeport Boss 4 and a 2J ……love the mighty Bridgeports!!
    W. Smith, Mission Viejo, CA
  2. #222
    Jun 2011
    695
    Thanks! I'm excited to get back on the project. I'm letting the concrete "acclimate" before I continue.
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  3. #223
    Nov 2005
    334
    IN HOUSE & READY FOR INSPECTION!!
    The suspense is over!!
    ….and a close examination is in process.
    It appears the cores were located properly and the cavities they
    created are cosmetically satisfactory and functionally acceptable!!!
    The surface finish of the overall casting could be better but most
    of those surfaces will be removed in the Blanchard Grinding &
    Finish Machining process.
    Take a Look.....
    Blanchard Grinding next post.
  4. #224
    May 2013
    149
    It certainly makes sense to cast rather than fabricate.
    Wisdom results from foolishness!
  5. #225
    May 2005
    3920
    Thanks for posting.
    Quote Originally Posted by CNCfun&games View Post
    Years ago I was working with a guy rebuilding some old machines. He went overboard with grinding and filling of the castings. By the time he was done the machine had a finish that would have put many show cars to shame. Sometimes a machine looking like a machine is a good thing. After all if you are afraid to scratch your machine it won't be used.
    Take a Look.....
  6. #226
    Nov 2005
    334
    HI Wizard!
    Wizard: I take your point on not going overboard on grinding and filling
    I’m not advocating “putting lipstick on a pig”.
    The bottom view of the Base for our Bridge mill is an example of a desirable “as cast” surface..
    Attention was paid to block sanding the pattern on both top & bottom sides of the match plate.,
    And the results were a pleasant surprise and makes painting soooooo easy.
    Just added the Blanchard Ground Top View for fun.
    W. Smith Mission Viejo, CA
  7. #227
    May 2005
    3920
    Nice! I still haven't figured out exactly what you are building here, however the workmanship is beautiful!
  8. #228
    Nov 2005
    334
    Zenji: I agree with you-There is some beautiful Fabricated stuff out there, but it's not my thing!!
    Machining Completed!!
    The Spindle Housing has been inspected and all critical dimensions were met.
    Will install the 4.724 6 in. (120mm) Spindle and see how things look.!
    W. Smith, Mission Viejo, CA.
  9. #229
    Dec 2004
    1865
    Looking good!!!!!!!!!!!!!!
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
  10. #230
    Nov 2005
    334
    What Next??
    TOTALLYRC.......Thanks!!
    Wizard...... "Nice! I still haven't figured out exactly what you are building here, however the workmanship is beautiful! "
    Wizard.... Thanks for the comment on workmanship.
    1.-We now have a machined Spindle Housing tooled and ready to go.
    2.- We previously designed and built a 2 axis Gang Tool slide which was successfully installed on
    a couple of stripped down Hardinge lathes.
    3.- Now if we could build a cast lathe bed we might be able to put a nice Benchtop Gang Tool Lathe together.
    Sounds like fun.........but we have 3 Bridge Mills in various stages of assembly with a higher priority...We'll see!
  11. #231
    Nov 2005
    334
    More Lathe Info...
    A few more details on the Benchtop Lathe Concept.....
    Enclosed are photo's of the 2 Castings which make up the Gang Tool Slide Assy.
    The Base Casting weighs 123 # and is the 2nd largest casting we have designed so far.
    The X Axis Cover weighs 45# and supports the gang tool channel.
    The two layouts are a couple concept studies.
  12. #232
    May 2005
    3920
    Pretty interesting! Is this something intended for production? By production here, I mean manufacturing the lathes for resale. Just for the sake of completeness what sort of capacities are we looking at here?
    You must be one busy pattern maker! By the way the castings look nice.
    The channel appears to be bolted on, is that the long term play here?
  13. #233
    Nov 2005
    334
    More Lathe Info...
    More info. On the Lathe Concept
    Wizard: Travel on the existing slide is X= 11.5 in., Y= 9.5 in.
    The Channels have been replaceable tool Steel for awhile.
    This modification became common because a tool crash could damage
    the whole x axis casting so the removable channel was introduced.
    We will probably build a couple Lathe's just for fun. The base
    will require some cogitation to determine if it should be one piece or
    a cast base with a sheet steel apron.
    The next order of business is to finish the 3 Bridge Mills that have been gathering
    dust these many months.
    The Bridge Mill configuration is very strong and I'm anxious to test it in the various
    bearing iterations under power.
  14. #234
    May 2005
    3920
    We dealt with that problem some time ago by glueing the tool post on with epoxy. Of course that was on a diamond turning lathe where cutting depths where only a couple of microns.
    Put it into production! I hate to ask how much it will cost though.
    Yes finish them up! I find the designs interesting to say the least. I don't like the cutout gantry beam but that is a minor quibble.
  15. #235
    Nov 2005
    334
    Background information
    [ I find the designs interesting to say the least. I don't like the cutout gantry beam but that is a minor quibble.[/QUOTE]
    WIZARD:
    The first CNC Bridge Mill I constructed in 2001 incorporated
    the cutout gantry beam and it provide to be quite
    effective in protecting the ballscrew and double nuts from contamination.
    It was retired about 2 years ago for retrofit, only because the old DOS Computer
    died. The round motors were replaced with the new square motors and a Gecko 540
    quad drive assembly was installed. It should be running soon.
    On moving Gantry Router the same Beam Configuration was used but the cutout was
    rear facing. It will see alot of Corian and wood products so the ballscrews will require
    extra protection and also a vacuum pickup.
    The bridge mill configuration is very strong and I'm anxious to test it in varying
  16. #236
    Nov 2005
    334
    More work Required
    Work Resumes on the Bench Top Bridge Mills
    Thanks Fann Blade!!
    Finishing 2 of the 3 Bridge Mills which are partially assembled is
    the next order of business. One with a Cast Iron base, the other
    with one of the 18” x 24” surface plates we purchased some time ago.
    Travel for #1 is 12” x 12” x 6”, travel for #2 will be 12” x 18” x 6” or
    About the same as one of my Bridgeports,,,,,pretty good for a
    Bench Mill form factor. Might end up a nice 2nd. OP mill afterall !
    The steel Z axis parts will have to be collected for inventory purposes,
    and several missing parts machined, before the 2.2 kw spindles can be
    mounted.
    Let the FUN begin.
  17. #237
    Nov 2005
    334
    More Pattern Making Required!!
    Work on Z axis patterns resumes.
    A decision to incorporate the two 3 HP 25000 RPM spindles into
    the Bridge Mills now in work will require finishing the patterns started many months ago.
    The fixed element of the Z axis can be still be fabricated from CRS but the spindle support
    will be cast because it will conform to the large Diameter of the spindle body thus saving
    about 1.5 inches in overhang..
    For maximum Strength these are Steel & Cast iron machines!
    Should be fun!
  18. #238
    Nov 2005
    334
    Spindles & Vector Drive located
    After locating the Spindles for the two machines currently in assembly,
    the overall dimensions were checked against the drawings and the existing
    patterns for conformity. It's been about 2 years since all the components
    were gathered in one place and I needed to visualize my current position &
    where I was going! Linear rails, ball screws, mounting plates, couplers.....the works
    needed to be brought together for both machines!!
    More work than I anticipated...no critical shortages so far....
    Hope to show some real progress soon!
  19. #239
    Nov 2005
    334
    Re: Will build a Benchtop mill including Castings! Comments appreciated.
    Several Accessories for the Bridge Mill are under investigation.
    Bought a couple of castings from Grizzly
    They are the rotating column support for the G8689,-LMS3900 or the Seig X2
    Thought they could be the basis for a nice 12" Trunion table.
    So here goes……..the meandering around again
  20. #240
    Feb 2006
    1187
    hey Smith good to see your still kicking!!! Great progress since the last time I checked this thread!!!
  1. Convert a 2 axis Cross Slide to CNC-comments appreciated!
    By CNCfun&games in forum Benchtop Machines
    Last Post: 10-25-2017, 06:21 PM
  2. Will Build a Moving Gantry ROUTER-comments appreciated.
    By CNCfun&games in forum CNC Wood Router Project Log
    Last Post: 12-25-2016, 01:06 AM
  3. DIY benchtop mill build
    By mkuivamaki in forum Benchtop Machines
    Last Post: 03-19-2014, 08:54 AM
  4. Designed from the ground up - including castings
    By Hack in forum Vertical Mill, Lathe Project Log
    Last Post: 02-09-2012, 11:09 PM
