Jack build away - really, i think its great the contribution to diy EG science you guys are making, but do you understand the commercial applications you reference, its modulus of elasticity, how section and modulus of elasticity effects rigidity, how cutting forces effect the structure and how vibration dampening works? I would not make a mill column or lathe bed of EG. I hope I'm wrong because then you've discovered and developed techniques for a wonderfully flexible diy build medium....however I've not received a response based in engineering that addresses the issues I raise. mostly responses are along the lines of we hope and wish it isn't so so we're going ahead anyway. you can design the base to suit the material - better however to include material selection as part of the design process. my point is to achieve a given rigidity with only EG, the size, weight and expense will be significantly higher than with steel and EG. do you refute that? actually, doesn't matter, stated my point, good luck with the build.
