587,974 active members*
4,304 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy-Granite machine bases (was Polymer concrete frame?)
Page 124 of 253 2474114122123124125126134174224
Results 2,461 to 2,480 of 5053
  1. #2461
    Apr 2007
    777
    Howdy all,
    My new building is acquired and the city has signed the first of two inspections for the electrical in my workshop! I'm on the way towards real data!!!!!
    Congrats to Walter on the pour of the Tabletop epoxy. I still think it would be easier to use the 37-127 and 37-606 as the surface as it's much lower viscosity will allow it to level better.
    For metalworking precision, I disagree with Larry that you can mill the spoilboard to match the beam. If you rotate the cutter more than a tiny fraction of a degree from exactly parallel with the spoil board, when you mill them to one another, you will get a bunch of regular and unremovable ridges, the severity of which will depend on the size of the cutter.
    As for the torsion box idea, it may solve wood working problems and make an okay base for a surface plate but I doubt however it will get the kind of precision required to build large metal parts accurately. It's a good start but I think it's an insufficient end.
    --Cameron
  2. #2462
    May 2003
    792
    DIY Epoxy-Granite surface plate
    Yay! this is exciting!
  3. #2463
    Jun 2005
    334
    Quote Originally Posted by ckelloug View Post
    --Cameron
    He was looking for a flat and level place to work.
    I've had almost 1500 lbs on mine with only .005 deflection. I wouldn't leave that load on there very long because wood stretches.
  4. #2464
    Jul 2006
    1256
    Walter sure is exciting.If I may quote Martin,what about"Sporty"?
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
  5. #2465
    Jun 2005
    334
    Sporty! Damn he forgot the pretty woven Carbon Fiber mat!!! Redo!
  6. #2466
    Jun 2005
    334
    Interesting observation
    After mixing a dozen or so EG formulas I can say this:
    You know you have the correct packing in the formula when you can easily mix it with 10% epoxy.
  7. #2467
    May 2003
    792
    By volume?
  8. #2468
    Jun 2005
    334
    yes, by volume
  9. #2469
    Jun 2005
    334
    Current formula
    Add 1/6 by volume the following:
    • #6 Agsco Brown
    • #4 Agsco Quartz
    • #2 Agsco Quartz
    • #2/0 Agsco Quartz
    • G800 Zeeospheres
    • G200 Zeeospheres
    Add 10% resin based on the volume of aggregates, after mixing and tamping. Stir in resin and vibrate until throughly wetted.
    It is much faster and easyer if you use BYK-A 525 air release additive at 0.5% and BYK-W 969 Wetting agent at 2%.
    So if you have 150 ml of aggregate you add 15 ml resin, 0.075 ml BYK-A 525, and 0.3 ml of BYK-W 969. Have your pipette's ready for the last bits .
    It's not an exact science therefore, if the mix is too clumpy then add a few more ml of resin until it combines.
    Jack
  10. #2470
    May 2003
    792
    Quote Originally Posted by jhudler View Post
    lol Jack
    How about that borosilicate glass.. Are you going to try it? Personally, I think it's a pretty cool idea.
    Larry,
    Remember the channels? http://www.cnczone.com/forums/showpo...&postcount=195
    they're back..
    I'm trying to match the curvature of the earth lol
  11. #2471
    Jun 2005
    334
    Quote Originally Posted by walter View Post
    lol Jack
  12. #2472
    Jun 2005
    334
    The other day I was finger joining some wood and the thought hit me that this would make an excellent bit to create bonding grooves in aluminum way beds.
    http://www.rockler.com/product.cfm?O...Select=Details
  13. #2473
    Apr 2007
    1955
    Hi, I missed that the torsion box idea was for me. Anyway, it would be nice, but out here in CA, there are no basements, not enough yard room for a workshop, and a just big enough garage to get by. I don't own a table saw or drill press - no room. That is why the router has to do double / triple duty, even if that means it is "not the right tool" sometimes. I am trying to get away from doing everything by hand.
    Thanks for the idea though.
    Walter - double checking - did you obtain that flat surface (I know with the fan stuff) with just gravity settling ? Now I wonder if I should just pour a thin EG layer on the garage floor - maybe 1/4 - 1/2 in thick.
    I need to go back and look - maybe I can just pour some of that epoxy that is being used in the EG formulation on the floor and let it cure as is.
    I was searching for some info on self-leveling epoxy, and noticed that Dupont makes a fluorosurfactant under the Zoryl brand. The purpose is to reduce surface tension (so it will flow flat better, etc) There are a number of variations of this material for specific applications, but what was most interesting, is that the general chemical family is not so different than synthetic vacuum pump oil.
    http://www2.dupont.com/Zonyl_Foraper..._techinfo.html
    I did a quick scan, and it looks like the FSH formulation is probably closest to epxoy use.
  14. #2474
    Jun 2005
    334
    Speaking of "Sporty"...
    Has anyone any experience with Gelcoat?
    Love this EG stuff but like Ford said "You can have any color you want, as long as it's black".
    Looking at molding something large and would like another color other and black.
    As someone mentioned before (Larry?) any mold release you use is just sanded off.
    So it seems that Gelcoating the mold and adding a thin mat of fiberglass would alleviate this problem. Not to mention a "Sporty" looking color. Gelcoat can be clear so the mat could be a nice sporty looking twill weave carbon fiber fabric.
    Any problems with this? Pointers? Products?
    What about something called "Tooling Gel Coat", can this be used to coat the interior of a wooden mold?
    I read that Gelcoats cure anaerobically and require that it is backed with resin and reinforcement mat. Is this always true?
    Jack
  15. #2475
    Jul 2006
    1256
    Harryn,I would not bother searching for leveling epoxy for your floor.Precision Epoxy already has it figured out.3X6'should not cost too much.It is not a good idea to use the E/G resin as an ESP[epoxy surface plate] as TT{table top epoxy}is formulated for the task and has air release addatives etc.If you use laminating or casting resin for an ESP,you may get amine blush which is a waxy cloudy surface.Your high gloss plate will not be glossy after a few days cure.
    Good stuff Walter.You have been very busy.
    I might add on torching or the heat gun.They are only to release air not to provide faster curing.As soon as you don't see air bubbling out stop using the torch or gun.
    What about trying vibration to level?
    Larry
  16. #2476
    Jun 2005
    334
    Quote Originally Posted by harryn View Post
    Just remember that floor when wet will be slicker'en snot!
  17. #2477
    Jul 2006
    1256
    Jack,The German guys were having release problems probably from vibrating the aggregates and it acting like sandpaper on the mold surface.Walter solved the problem with sandwich wrap or some of the plastic materials mentioned before.
    Polyester gellcoats must be backed up,say in this case your 635 resin with a glass cloth,carbon fiber,etc.
    Tooling gelcoat is for master molds.It is extremely hard.Yes you could coat a wooden mold if it is sealed well and waxed.
    Sporty color?Just add pigment to the resin.
    Larry
  18. #2478
    Apr 2007
    777
    Harryn,
    Thanks for the zonyl info. Zonyl FSH in not suitable for epoxy use though other zonyl formulations are. It is for aqueous solution which epoxy is not. I am not trying to be critical as Zonyl is good info, I just want to keep a bunch of zonyl FSH samples out of the waste stream. Dupont is also harder to get samples from than other vendors. (added via edit It looks like Zonyl FTS is the one that would work for our application.
    I've got samples of 3M Fluorosufactants Novec 4430 and Novec 4432 which are suitable for use in epoxy. 4432 is the most wetting fluorosurfactant in the 3M line. Jack also had a wetting agent from BYK which I hand't considered.
    I'm busy getting E/G stuff out of my kitchen and into my new building so I'm monitoring the discussion but haven't got much to add right now.
    Also, Harryn, are you going to be around the week of December 12? I'm going to be in the bay area for my day job part of that week and the following week.
    Walter and Jack,
    Kudos on your surface plate and tests respectively. I am totally excited about what you guys are reporting and am waiting with baited breath to get started doing instead of pontificating!
    :cheers:
    Regards all,
    Cameron
  19. #2479
    Jun 2005
    334
    Quote Originally Posted by lgalla View Post
    Sporty color? Just add pigment to the resin.
    Larry
    The Zeeospheres are a pigment. Unless we use the White version of Zeeospheres then we'd have a chance of using other colors. There's no W-810 so we'd have to do another formula.
    Guess I'll experiment with this too.
  20. #2480
    Apr 2007
    1955
    Cameron - Yes, PM on its way.
    Harry
  1. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  2. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  3. Replies: 9
    Last Post: 01-15-2014, 11:39 AM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. Epoxy-Rice Machine Bases (was Polymer rice frame?)
    By mdierolf in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2008, 04:16 AM
