Originally Posted by
keebler303
The analog connection is simple. I showed on my drawing using the builtin 10V supply from the VFD to power the analog output from the BOB. This may not let you get full 0-10V output from the BOB which may reduce your top speed. You can use a separate power supply (wall wart) to power it with 12 volts.
Matt
If there is no scaling in the unit itself, it may be possible to achieve higher rpm by upping the max freq. (unobtainable) set point?
Al.
Albert E.
