588,686 active members*
5,966 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy-Granite machine bases (was Polymer concrete frame?)
Page 132 of 253 3282122130131132133134142182232
Results 2,621 to 2,640 of 5053
  1. #2621
    May 2003
    792
    Nope. I finished the castings but didn't think it was good enough, so I shelved it. Frankly, I don't really care anymore.
  2. #2622
    Apr 2007
    777
    Walter,
    Are you talking about the little mini-mill base or your grand router?
  3. #2623
    May 2005
    89
    Found this, nothing new but still: http://cmpnd.org/content/view/92/
  4. #2624
    Jun 2006
    16
    Question Quarz sand
    Can you take a look at the quarz sand in the link. It is 98% SiO2 sand used for water filtering in pools. Size up to 4 mm.
    http://www.kerkosand.sk/files/KA_PP_CZ05.pdf
    They make a sand for casting too, but the size is just up to 1.4 mm.
    http://www.kerkosand.sk/files/KA_KS_SK03.pdf
    Regards jstransky
  5. #2625
    Jun 2005
    334
    jstransky,
    Sand filters for pools use a specific size of sand so that is does not pass through the screens and also to minimize hydraulic friction.
    This is why pool sands have a large quantity of one size or a narrow range of aggregates. Any fines in the sange will be picked up by the pool cleaner and filtered out.
    Pool sand has many contaminates that should be acid washed to remove.
    The Kerkosand is a much better material for EG. It also has better grading (sizing) data and very clean.
    Jack
  6. #2626
    Jun 2006
    16
    Sand size ?
    What do you think about the maximal grade size - 1.4 mm. Isn't it too small ?
    jstransky
  7. #2627
    Jun 2005
    334
    jstransky,
    If that is all you have on hand then go with it. If you can find some larger aggregate such as crushed granite or whatever is in your area.
    Jack
  8. #2628
    Jun 2005
    334
    Surface Puck!
    Ok I lapped it last night.
    Some of those scratches are 2 micron and smaller. Going to fast and not practicing good cleanliness between grits.
    Cool part's in the video.
    It's 100% 3M Zeeospheres 200 and US Composites 635 2:1 Epoxy. 24 cure, then 2 hours at 50C.
    Diamater is 100mm, ~35mm thick and the surface is flat to within +-.0005 or ~12 microns over 80mm.
  9. #2629
    May 2005
    89
    That's sick! Unbelievable cool.
  10. #2630
    Nov 2006
    51
    Quote Originally Posted by lgalla View Post
    Walter your picture reminded me of E-bay listing #320203796630
    The blocks are sr-20 rails 460mm long.One rail and one block is$25.00
    The guy only has 250 of them.Remember SR's are for horizontal use.
    Larry
    I just wanted to thank you for posting this auction.
    I ended up scoring 14 sets of them for use in my machine.
    And if you hadn't have posted this I would have never known about them.
    I would have just sent you a PM but your box is full.
    Joseph K.
  11. #2631
    May 2005
    674
    Very nice work, Jack. No de-airing agent?
    Where did you get your Zeospheres? Same place as Walter? How much did you guys pay?
  12. #2632
    Jun 2005
    334
    Walter purchased his at Cary Co. Mine was from Ribelin Supply in Garland, TX.
    The 800/850 run about $25-$30 a 50 lbs bag, the 200 from $35-$50 bag.
    If they quote you a ridiculous price per bag or pound, then don't hesitate to call them on it. They might send you to another sales department or salesperson, but you will get the lower price. If not move on to the next distributer or call 3M.
    Oh, you do! want to pick this up.
    Jack
  13. #2633
    Apr 2007
    777
    Jack,
    Your video of lapping the E/G block and wringing it to a gage block is remarkable. Do you have a story on the process behind creating the E/G block? How level did the E/G get on it's own and how much lapping was required to get the surface into that state?
    Regards all,
    Cameron
  14. #2634
    Jun 2005
    334
    About a little over an hour.
    I had originally cast it upon a black granite surface plate, but the release agent was visible in the cured flat. I used a release agent because I didn't want to trust micro-crystalline wax on its own.
    So I ended up reverting to using sandpaper for the first few steps.
    Something this small is easy to do with sandpaper up to 800 grit.
    I then switched to diamond paste on flat glass down to 1 micron.
    That was before... I never really mentioned it online because it was such a small thing.
    I then used it as a coaster on my desk.
    When Walter wanted to see pictures I re-poured a new 1/4 inch top and just used sand paper from 150 - 1500.
    Something larger than this would require flat glass on a surface plate, or some serious time on surface grinder, or laser interferometer with the optics to calibrate a surface plate, or an autocollimator. Latter two requiring some serious patience.
    Where is it now? Locked to my surface plate... need to get the air hose on it and pop it off! Make an excellent vacuum preloaded air bearing mount for a indicator on a surface plate .
    Jack
  15. #2635
    Oct 2007
    62
    Quote Originally Posted by jhudler View Post
    Jack
    funny that you mention that. I have been lurking in the back of this thread for a few months and that is what I'm currently researching.
  16. #2636
    May 2005
    89
    Does anyone know any price for moglice? I really want to try to make my own hydrostatic bearings. Besides does anyone know of the minimum amount of space required for moglice to fit, i hope you understand what i mean.
  17. #2637
    Dec 2004
    524
    Quote Originally Posted by Eson View Post
    Please let me know what you find out. I'm interested in using moglice as part of a DIY low friction, low backlash leadscrew. The idea is to take a plain old acme screw, lap it against a brass nut until it is uniform and then make a nut lined in moglice.
    The moglice site claims that it is usual to have clearances of .0002 inches on an accurate screw and that this can be polished to .00005. So, if we could lap a screw to be consistent to 50 millionths, we could build one with a backlash of a tenth (twice 50 millionths).
    That's not bad for DIY.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
  18. #2638
    Apr 2007
    1955
    Quote Originally Posted by lerman View Post
    Ken
    Hi Ken, I had no idea you could hand lap a thread to that kind of accuracy. Pretty amazing.
  19. #2639
    Jul 2006
    58
    I haven't seen most of this thread, so pardon me if it had been discussed. Has anyone given any thought to using some ground fillers like slate flour, fly ash, rottenstone, floated silica or the like? Just noticed that some of these materials are not unlike granite in their composition and should be dirt cheap as a fine filler. The old "Keystone filler" was used many years ago as a filler/finish for cast iron machine tools.
  20. #2640
    Apr 2007
    1955
    Quote Originally Posted by USMCPOP View Post
    Hi - Thanks for joining into this thread. It takes a bit of digging, but the general idea has been around obtaining "high end" performance in an epoxy / filler mixture. The short story, is that this entails mixing well known / sized fillers with specific size ratios and minimizing the epoxy content, as well as finding ways to minimize air bubbles and enhance the bonding to the filler.
    There still is room for improvement in the mix, especially if you start to move into tensile strength areas. The trade off has been increasing cost and ability to obtain the right size materials.
  1. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  2. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  3. Replies: 9
    Last Post: 01-15-2014, 11:39 AM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. Epoxy-Rice Machine Bases (was Polymer rice frame?)
    By mdierolf in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2008, 04:16 AM
