588,506 active members*
6,490 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy-Granite machine bases (was Polymer concrete frame?)
Page 134 of 253 3484124132133134135136144184234
Results 2,661 to 2,680 of 5053
  1. #2661
    Jun 2005
    334
    Quote Originally Posted by lerman View Post
    What I had in mind was first creating a special nut to use as a lap. Perhaps casting one around the screw using babbit or lead or plaster or plain old epoxy would work. The lap would be six or eight inches long.
    I would read about Henry Rowland and his adventures in making lead screws for ruling engines.
  2. #2662
    Oct 2003
    153
    Quote Originally Posted by jhudler View Post
    Acrylic Water would be in the category of paints, it's an emulsion that dries.
    It does not cure with a hardener like epoxy (almost no shrinkage), or catalyze like Polyester (a little to a lot).
    I stopped by hobby lobby on the way home from work today and they had this stuff it's a 2 part epoxy. haven't found an MSDS or anything like that yet though.
    http://www.crafta.com/32012-z.html
    Dan Sherman
  3. #2663
    Jun 2005
    334
    Dan, What does it say on the front. I can't make out the ingredient.
  4. #2664
    May 2005
    89
    Well... I guess that would depend on how much hydraulic force you can exert and the point at which moglice detonates from dieseling.
    Are you creating fixed opposable air bearings?
    Jack
    Well im not sure what i am creating since i cant decide! Im sort of just exploring the possibilities. However my dream is a tri/hexapod with linear actuators and the hydrostatic/air bearing would support the ballscrew since ball bushes will build too much. I have CAD-drawings of my idea but not avalible now.
  5. #2665
    Jun 2005
    334
    It's a Urethane (Isocyanate), not an epoxy.
    http://www.pdmurethanellc.com/quick-water.htm
  6. #2666
    Jun 2005
    334
    Quote Originally Posted by Dan S View Post
    That Quick Water is almost 3 time the cost of epoxy.
    go to http://www.uscomposites.com/epoxy.html and order the EPOX-6355561 (16 oz part A and 8 oz part B).
    If you order it by tonight you should have it by Thursday.
    Jack
  7. #2667
    Jun 2005
    334
    Quote Originally Posted by Eson View Post
    Are you trying to build something like a Hexagide?
    http://www.indoor.flyer.co.uk/kinematic.pdf (third picture or so)
  8. #2668
    Oct 2003
    153
    Jack
    I have half a gallon of general purpose system 3 epoxy. I worked with several different brands in the past, I'm just worried about mixing up such a large batch (worried about the heat). Though to be honest, i have never mixed up a batch with a bunch of aggregate in it, so maybe that will suck up some of the heat.
    Dan Sherman
  9. #2669
    Jun 2005
    334
    Yes it will however, how fast does this epoxy set?
    Do you have a link to the product?
    Jack
  10. #2670
    Oct 2003
    153
    Jack
    http://www.systemthree.com/
    I have both #2 and #3 hardner
    Attached Files Attached Files
    Dan Sherman
  11. #2671
    Dec 2006
    325
    Dan,
    Don't worry about the mix heating too much don't forget the quantity of epoxy is only 10% of the total mix by weight or if you prefer about 20% by volume. the heat is being absorbed by the rocks.
    Best regards
    Bruno
  12. #2672
    Jun 2005
    334
    Dan, You'd want to use the #3 hardener to keep the viscosity down. To add to Bruno's comment, no one has reported any signs of exothermic runaway.
    By volume that 1/2 gallon plus hardener (2:1) will yield 3.75 gallons or ~85 lbs using the current EG formula.
    If you use lead shot then you calculate your yield from space your filling with epoxy; which is ~38% (62% packing density). Roughly; the 96 oz of epoxy on hand would be 96 * 3 = 288 fl/oz of epoxy/lead shot. Lead shot is ~500 lbs per cubic foot and 288 oz would be 0.30078 cu/ft = 500 * 0.30078 = 150 lbs of epoxy lead.
    Might try a mixture of 00 and BB to get a higher density.
    Jack (warning this is a late night post... use at your one risk )
  13. #2673
    May 2005
    89
    I was thinking of a 'normal' hexapod because of the simple design, however i wonder if the ballscrews are so rigid and was thinking of stabilize them. Might be a good start anyway.
    http://hem.bredband.net/b235625/hexapod.jpg
  14. #2674
    Jun 2005
    334
    The hexapod or Stewart platform, is an inherently rigid system.
    You do not need to stabilize them.
    The rigidity comes from the size of the ballscrews, which is calculated based on the design loads the system will take.
    Jack
  15. #2675
    Jun 2005
    334
    Wow a idea just smacked me face or it's an obtuse day...
    You can take 6 screws and place them in 6 tubes (a little shorter then the screw) and fill it with a mixture of a Moglice type of EG. Wouldn't want to use Moglice here, it would cost a fortune.
    To use Moglice for this, you could try spraying >20 coats of PVA on a screws and then cast it in EG. The do the last casting with Moglice. 100 grams of Moglice should be more than enough! You could literally pour the Moglice in the screw tube (the other end was cast closed) and screw it back into the tube and allow the hydraulic pressure to push the Moglice back up and around the threads.
    The initial mold would have to incorporate something to align the screw parallel with the tube and that alignment aid would have to cast in place and for the final coating with Moglice so that all the threads would get an equal coating.
    Jack
  16. #2676
    Dec 2006
    325
    Alternate solution
    You can take 6 screws and place them in a tube (a little shorter then the screw) and fill it with a mixture of a Moglice type of EG. Wouldn't want to use Moglice here, it would cost a fortune.
    Jack,
    someone mentionned a few posts back to make an epoxy/zeeosphere putty.
    Would this be applicable instead of Moglice, perhaps add a small quantity of Teflon powder(or graphite is less expensive) to make it more wear resistant??
    BTW Eson you have a cool project in mind!
    Best regards
    Bruno
  17. #2677
    Jun 2005
    1436
    Er,one tube, or do I misread your idea Jack ?
    Universal joint at the top and bottom of each leg ?
    John
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
  18. #2678
    Jun 2005
    334
    Bruno, That would certianly make a good Moglice substitute. My only concerns are the hardness of zeeospheres acting as an abrasive. The addition of teflon powder might mitigate this.
    Molybdenum powder might be better. I think Moglice is mostly Molybdenum Disulphide powder; just a guess, I've never seen a MSDS on it to know.
  19. #2679
    Jun 2005
    334
    John,
    See picture. The cap's on the end could contain a divot or kinematic point that would help align the screw in the center. You would have to make a fixture to fix the tube parallel with screw and apply enough force to seat the screw in the divot.
    This fixture would have to be small enough to fit in the cooker for post cure.
    Jack
  20. #2680
    Jun 2005
    334
    I've got to get me some Moglice, the last time I saw this stuff was 18 years ago.
  1. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  2. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  3. Replies: 9
    Last Post: 01-15-2014, 11:39 AM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. Epoxy-Rice Machine Bases (was Polymer rice frame?)
    By mdierolf in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2008, 04:16 AM
