587,564 active members*
3,315 visitors online*
Page 15 of 17 51314151617
Results 281 to 300 of 329
  1. #281
    Can't you drill out the cap and re-tap for a standard size, higher quality fitting?
  2. #282
    Dec 2006
    259
    That's a good question. I didn't even think about that. Drill out, re-tap, use standard fittings from either Agent Orange or The Smurfs.
    I would have to look and see what size O-rings are used inside the cover to know for sure if there is room for that though. I tend to doubt it, but until you look you don't know. I have two friends who ordered spindles with me as a group purchase, and the spindles are at the house of one of them and as yet I haven't seen them myself to know. I will keep everyone here apprised of the details as I follow up on this.
    Don
  3. #283
    Feb 2010
    3447
    Quote Originally Posted by DonW View Post
    Don
    I was going to drill and tap mine up to a normal size, but tried to replace them first with larger ones. The local shop said most Chinese manufacturers even use there own "metric" non standard threads since they figure no one will be replacing certain parts. unable to find replacements, i ordered the correct tubing and seems to work just fine. I didnt drill them up because the small orings that are inside. Didn't want to risk a leak. Tried to take the back of the spindle off, but it was on there pretty well even with all the bolts off. I just left it as is.
  4. #284
    Dec 2006
    259
    Where did you order the correct sized tubing? China? Canada? Europe? McMaster-Carr?
    BTW...diyengineer - I ordered the cable from igus. It turns out they are located ten minutes from me, so I just went over and picked it up.
    The next day, I went to All Star Adhesives to pick up some vacuum gasket material, and they are only twenty minutes away. Apparently, I'm in the right area for some of this stuff!
    Don
  5. #285
    Feb 2010
    3447
    Don
    Sorry, by "ordered" i meant i traveled to home depot. lol.
  6. #286
    Feb 2010
    3447
    Don
    lol! You are in a good area haha! How do you like the allstar products? i am going to order up a bunch fairly soon!
  7. #287
    Dec 2006
    259
    The All Star adhesives products are terrific. They have all kinds of great stuff there. It's a family owned and operated business, and they are terrific people. If you son't see what you're looking for, chances are they can make it. Need a wider tape? No problem.
  8. #288
    Dec 2006
    259
    Quote Originally Posted by diyengineer View Post
    Ah..interesting. The tubing we found at Home Depot (aka Agent Orange) was either too small or too big, so we just ordered the correct size from McMaster Carr - Part# 5958K14, should anyone else need to order the stuff. Cheap too! $13 for a 100' roll.
    Don
  9. #289
    398
    Cool on finding 8x6mm tubing. My local industrial hose and tubing supplier claimed they could not get it. Strange.
    But since I live in Canada MM Carr is a non starter.
    My method seemed to work.
    Thanks for the information. I will keep it for next time.
    Dave
  10. #290
    Dec 2006
    259
    So we got them all running. Smooth...and very quiet compared to the Porter Cable router I was running. One of the guys had an issue with his water hose connector striping out though. Not sure if he tightened too hard, or if it's just a cheap part.
  11. #291
    398
    DonW
    Awesome.I am happy with mine too.
    Dave
  12. #292
    Feb 2010
    3447
    What is everyone using for a wrench? I cant find a good ER20 wrench online for tightening and loosening.
  13. #293
    Dec 2006
    259
  14. #294
    Feb 2010
    3447
    Thanks.
    Also,
    Has anyone came up with a DIY spindle lock for these? I'd like to use a dial test indicator but the spindle doesn't lock! ideaS?
  15. #295
    Jan 2008
    1543
    Results for Tool & Work Holding:ER Spanners is another option for spanners.
  16. #296
    Feb 2010
    3447
    Anyone interested in a simple spindle lock for the 1.5/ 2.2 KW spindles?
    I was thinking about making a batch of them. I want to be able to use my Dial test indicator and a few others items without the spindle wobbling all over.
    Let me know! thanks!.
  17. #297
    Feb 2010
    3447
    sorry to all who messaged me. My PM box was full!! Feel free to contact me now, i cleaned it out! I am finishing the design tonight and will start a new thread that will provide price, pictures, etc. I will a provide link shortly.
    Thanks! :P
  18. #298
    Oct 2011
    water pump for chinese spindle
    i have a 0.8kw chinese water cooled spindle and i'm installing a wtaer pump for it using a pump/filter for aquariums.
    any idea what should be the water tank volume and the pump's power (liter/hour) so i could get the most efficient cooling system.
    if someone could give me the formula to calculate a water tank volume and a pump's power in relation with the spindle's specs.
    i would be much grateful
    btw this is my first post here among you fine people on this great forum
    ben
  19. #299
    Jun 2006
    23
    What is the minimum speed that work well a 2.2 kW chinese spindle?
    This spindle and inverter :
    Thanks.
    http://www.cnczone.com/forums/diy-cnc_router_table_machines/125729-altcnc.html
  20. #300
    398
    With that inverter pictured, I believe 9000 rpm is where the torque starts to reduce significantly. If you get a more expensive Vector drive you will have a lower torque inflections.
    Dave
  1. CHINESE SPINDLE 2.2KW
    By Ed Williams in forum Open Source CNC Machine Designs
    Last Post: 03-29-2016, 04:07 PM
  2. chinese spindle
    By roger de poger in forum DIY CNC Router Table Machines
    Last Post: 05-02-2011, 12:43 PM
  3. Chinese Spindle opinions
    By ennova in forum DIY CNC Router Table Machines
    Last Post: 02-24-2010, 11:23 PM
  4. Bit Slip on Chinese Spindle
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 12-05-2009, 11:23 PM
  5. 2.2 KW Chinese Spindle ? runout
    By Ed Williams in forum DIY CNC Router Table Machines
    Last Post: 09-23-2009, 05:52 PM
