588,687 active members*
6,250 visitors online*
Page 15 of 23 51314151617
Results 281 to 300 of 459
  1. #281
    Dec 2007
    578
    Re: Hurco BMC20 Dynomotion Retrofit
    Been doing some more testing cutting air I have a Gcode that has small arcs and lines (high speed toolpath) making 2 slots that are .280" wide with a .25" end mill. Ran this same program at work on a "industrial" machine with no problems, actually looks like table is vibrating its so fast
    When running gcode on my mill, speed of axis look good at start, then after a few seconds axes start slowing down. Then if i pause program and resume, speed of axes again looks good at start and then slows down. I tried increasing the look ahead time. This helps a little but what ever look ahead i have, axes will wait that long after i start gcode before executing gcode. And still slows down after a few seconds.
    Attached is gcode. Any ideas?
    Troy
  2. #282
    Dec 2007
    578
    So started reading the section of manual about the Trajectory Planner settings (Understood it a little bit. . And set the Break Angle(45), Look Ahead(1), Collinear Tolerance(.0002), Corner Tolerance(.0004) and Facet Angle (1.6).
    Tom or anyone, do these settings make sense?
    So far the motion of machine is fairly smooth with no slow down that i can notice by eye and ear but there is some hard start and stops that is noticed at beginning and end of tool path where the moves are larger.
    Troy
  3. #283
    May 2012
    537
    Machine looks good in video, very fast. Good job. I also had to set break angle very high to avoid slow downs. I think i set mine to over 100 degrees to try and make 90 degree turns faster. Not sure how much it helped, but didnt see any other issues.
    Whats your axis acceleration in the trajectory planner? The Jerk setting in kflop is only applied to rapid moves, for interpolated moves it is not used and full acceleration is applied right away and it can cause some harsh motion unless you set acceleration very slow. Kind of disappointing not to have jerk on coordinated moves. This is probably the only major feature kflop is lacking from an original controller. Seems like we have to live with fairly slow accleration or rough motion. Be sure to add a low pass filter to help smooth motion. This will round corners more, especially at high speed. Most industrial controllers work this way as well to an extent, not a real big deal, just slow down your finish pass. I think i set mine somewhere between 0.010 and 0,020 seconds, made a huge difference and allowed me to bump up acceleration slightly. Lower is more accurate obviously and larger will run smoother.
    I guess our hardware is already capable of doing 3rd order interpolated moves if only Kmotioncnc could process it that way. Maybe someday you could add this Tom? I think i saw a post before where you mentioned it was very complex, but other controllers do it, I bet you could get it working too.
  4. #284
    Dec 2007
    578
    My Accel is 30 and Vel is 12. Tried higher Accel and Vel but didnt help much.
    I have a filter within main init program but not after like the manual on Trajectory Planner suggest as an option.
  5. #285
    May 2012
    537
    I couldnt reach 30 IPS^2 on my machine without my machine sounding rough in some situations. I think i had to live with around 15.
    The coder for the low pass filter is below, makes a big difference. I would try much larger number then in sample program below though.
    #include "KMotionDef.h"
    main()
    double Tau = 0.001; // seconds for Low Pass Filter Time Constant
    KLP = exp(-TIMEBASE/Tau);
    printf("Tau=%f KLP=%f\n",Tau,KLP);
  6. #286
    Dec 2007
    578
    Quote Originally Posted by mmurray70 View Post
    main()
    Where did you place this code? In the Main Init C code or?
  7. #287
    May 2012
    537
    Quote Originally Posted by Need TECH Help! View Post
    Yes in the main init file, I placed it just after all the settings are set for each axis and it worked fine.
  8. #288
    Dec 2007
    578
    This helped out nicely. Was also able to increase feedrate to 80IPM and shaved off over 4 seconds of cycle time. (Still cutting air thow. And Accel at 40.
    Will try to get a video of it soon.
    Thanks again,
  9. #289
    Dec 2007
    578
    Here is a little video of the test gcode of a high speed toolpath.
    https://youtu.be/pVHg96-1HY4
  10. #290
    May 2012
    537
    Those poor ballscews. I try and avoid really tight adaptive paths personally. But looks like its doing it fairly well
    Seems like your hurco is built more solid then my machine. My mill would sound terrible with that toolpath at that speed.
  11. #291
    Dec 2007
    578
    You should have heard ball screws before the fine tuning was done.
    I was fairly surprised by the whole design of this machine giving its year. This toolpath would be a "worst case" scenario, more of a acid test. Got another test cutting some plywood that i will post a video of later.
  12. #292
    Dec 2007
    578
    Here is a test cut in plywood that i think Tom will like.
    https://youtu.be/qLxeTYGQMDA
  13. #293
    May 2006
    4060
    TK
    http://dynomotion.com
  14. #294
    Dec 2007
    578
    Quote Originally Posted by TomKerekes View Post
    Hi Troy,
    Do you have any action configured for Halt in KMotionCNC | Tool Setup?
    Regards
    Hi Tom,
    Was there something that you working toward when you asked this? Concerning the spindle runaway when feedhold is pressed during a G84 tap cycle?
    Just to re answer, yes i have a C program that sets both CW and CCW bits for spindle to shut off and MDI a G80 and G40.
    Troy
  15. #295
    May 2006
    4060
    Hi Troy, Yes. In that case you might try temporarily removing the Halt Action to see if it is related. G84 will invoke M119 to run a C Program using some Thread. Is your Halt Action configured to use the same Thread? Regards
    TK
  16. #296
    Dec 2007
    578
    Hi Tom,
    I removed the C program from Halt action and the M30 action, but after i feed hold (not halt) during tap cycle the spindle still runs away to full RPM. Axis do not move.
  17. #297
    May 2006
    4060
    Hi Troy,
    Do you have an Action assigned to Feedhold?
    Please post the current Version of the Rigid tapping C program you are using.
    Regards
    TK
  18. #298
    Dec 2007
    578
    Nope. No Action for feed hold.
    Attached is Rigid Tap C program.
    Attached Files Attached Files
  19. #299
    May 2012
    537
    I still think you might be better off blocking feedhold to stay out of trouble. Its not an easy fix without major changes to the rigidtap program and init file. But if your set on getting it to work. Keep it mind that you dont actually want to do a normal stopcordinatedmotion like a normal feedhold would do. To properly stop while spinde is slaving in the rigidtapping program you need to just simply stop spindle and the Z will be still slaving and also stop with it and everything will stay in sync.
    You could probably set a userpersist variable to indicate tapping is active and in your init file, when you press your feed hold button it could check if tapping is active or not and then either stop the spindle if tapping or do a normal stop co-ordinated motion if tapping is not active. And your cycle start button could check for the same to resume. Another userpersist variable could be set in the tapping program to set which direction the spindle needs to be restarted in.
    Another issue you will have is if you setup feedhold to stop spindle and your almost finished and it coasts to the bottom it will restart again in reverse. If you turn tap by hand it could restart. A lot of complications and possible safety issues. Sorry i dont have any suggestions about the spindle ramp problem, but i just wanted to point these things out. Good luck with it.
  20. #300
    Dec 2007
    578
    Hi Murray,
    Having the feedhold turn off spindle i think would be the best way to handle it during a tap cycle.
    As for restarting and reversing at bottom of hole, can there be way to ignore this when in feed hold? Or maybe Estop whole machine? Would be safer to break a tap than harm someone.
  1. Local repairman for '92 Hurco bmc20 around Bristol, IN
    By Benkerst5278 in forum CNC Machining Centers
    Last Post: 07-13-2010, 03:32 PM
  2. HURCO BMC20
    By PCM in forum HURCO
    Last Post: 05-03-2009, 08:03 PM
  3. Hurco BMC20 with Ultimax 2 control
    By kwmkoester in forum HURCO
    Last Post: 04-30-2009, 11:52 PM
  4. Hurco BMC20 Post Prosser help
    By moorport in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-06-2007, 05:19 PM
