Originally Posted by
johnyswift
Ok from using equation (7.9) i have managed to find the eccentricity if using a compression ratio of 14:1 however as the equation is a quadratic there are actually 2 values. One is 0.29 and the other 0.65, does it matter which value is used? and i know these two values are for a flat flanked triangular Rotor.
The second question i have is regarding equation 7.8, the rotor width (w) is reffering to the length of one flank or the actually thickness of the Rotor?
Im just a bit confused in what direction i need to be going in as the e/R ratio cannot be determined for rounded flanks unless the (As) value is known equation (7.16)
All above questions are based on the chapter 7 article, any help would be very much appreciated
thanks.
