603,943 active members*
4,112 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > CNC Wood Router Project Log > WidgitMaster's Largest Steel Router Table Project 9ft x 5ft x 8" Water Cooled Spindle
Page 15 of 91 513141516172565
Results 281 to 300 of 1805
  1. #281
    May 2013
    204
    Bear in mind that those types of fans are usually rated at 0" external static pressure. They're more likely to see something on the order of 0.1" E.S.P.. couple that with the fact that prop type fans have a very steep curve and you may be short on cooling air.
    ...and in case I haven't said it yet, I am in awe of your machining skills.
  2. #282
    Dec 2004
    783
    FWIW my VFD is mounted in open air under the machine, temps in the shop are 100°+ F half of the year, and I have yet to see the internal fan on the VFD running, or felt the cooling fins on it be more than a few degrees above ambient.
    Sent from tapatalk
  3. #283
    May 2013
    204
    That's because it is rated for 40c (104 f). The problem is that an enclosure will hold the heat.
  4. #284
    Quote Originally Posted by kuroguy View Post
    Geez!
    One post makes me want to go shopping on eBay for squirrel cage fans, and the makes me slam on the breaks!
    So I'm going to hold off and get more parts made before I do anything electrical!
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
  5. #285
    Dec 2007
    2133
    The best muffin fans I've ever seen are the second hand ones from old servers, these are designed to move very large amounts of air and heat continuously.
    Whenever we scrap servers, I always rip out the fans and pass them around to mates.
    cheers, Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
  6. #286
    Dec 2004
    783
    Quote Originally Posted by aarggh View Post
    cheers, Ian
    Great if you can tolerate the noise I have a few server power supplies I use for powering chargers and they sound like a jet taking off
    Sent from tapatalk
  7. #287
    May 2013
    204
    I've got some time on my hands. The best thing to do is figure out what's going in the enclosure and tally up the heat from each item. The stepper driver manufacturer should be able to provide that data. I've already calculated the vfd heat. I can also make recommendations regarding the fans, but the first step is figuring out the heat load. Fyi, i'm an air conditioning engineer. This is what I do. As I said before, i'm glad to help.
  8. #288
    I really do appreciate your offer, but I'm months away from pulling wires! I haven't ordered half the components, or finished the schematic!
    The small box with the VFD will be mounted under the side of the table where the Cable-Track ends. My plan is to use a bigger box on wheels to contain all the electronics for controlling the steppers! This way, I can make a large multi-conductor cable to connect the two box's. I have included my current schematic in a downloadable ZIP file, it is in .jpg image format and too large to add as an image. If I reduce the image, it looses all the text details!
    Like I said, its going to be a while before I'm ready to think deeper into the electrical systems!
    Attached Files Attached Files
  9. #289
    Today I started on the bronze flange bearings, for the y-axis pivot plates. First I used the band saw to cut 4 blanks, then I placed them in the lathe. The 1st step is to face each blank, and turn the 2.000 diam +0-.003" Next I put the 3-jaw chuck with soft jaws on the spindle, and held the parts on the 2" diam. Now I can face them to the finish size, and rough down the diameter. Then I carefully turned the diameter & faced the inside of the flange, until they were to exact size.
    With the blanks done, I measured the depth of the outer pocket in each plate. Then I custom faced one blank so the bronze surface will be co-plane with the aluminum boss. Now I can use the mill's vise to press in the top bearings. But first I had to flip the vise jaws, so they were a little higher. The bearings all pressed in nicely, so I setup the mill for boring the finish diameter. The bottom bearing protrudes .0280", and will seat on the spot-face previously milled on the steel plates.
    The bores finished up nicely, and he assembly on the left side of the big router went together easily. All that was required was a hit with a led hammer, to bend the warped steel weldment out of the way.
    The right side of the router, required a little more attention! The weldment was warped, and there was considerable interference with the swing plate. So I inked up the high spots, and used a 2" air sanding disk to grind down the high spots.
    Now the y-Axis stepper motor assembly is officially finished, until everything returns from powder-coating! Then, I'll have to fit them again!
    Attached Thumbnails Attached Thumbnails 9x5_Router_607.jpg   9x5_Router_608.jpg   9x5_Router_609.jpg   9x5_Router_610.jpg
  10. #290
    This morning I played in the shop for a few hours, making the sheet metal plates for electrical junction boxes. First I band sawed 4x 1/8" thick plates, then I placed them on the mill table long side parallel. Then I place two large parallels on top, and clamped everything down. Next I milled the two over hanging edges until they were parallel.
    Now I clamped a parallel perpendicular to the mill table, using a large square to align it. Then I placed the machined edges of all 4 plates against the perpendicular surface, and clamped them down. Now, I can mill one end of all 4 plates square!
    Attached Thumbnails Attached Thumbnails 9x5_Router_613.jpg   9x5_Router_614.jpg   9x5_Router_615.jpg   9x5_Router_616.jpg
  11. #291
    Next I clamped a big parallel at 45-deg to the table. and again place the 4 machined edges against the parallel. Then I clamped a round stop to the table, so the machined ends of the plates had a solid stop to bank off of. Then I put some blocks & parallels on top of the plates, and clamped everything tight. Next I setup the mist coolant, and put a 1/4" 2-flute end mill in the spindle. Now I can mill through the 4 plates and get a 45-deg edge.
    Attached Thumbnails Attached Thumbnails 9x5_Router_621.jpg   9x5_Router_622.jpg   9x5_Router_623.jpg
  12. #292
    With the plate milled, I clamped them to a 2" thick block to see how they look on the big router. There will be one box on each side of the gantry, but one will have a 1 1/4" tube entering from top & bottom. These boxes will also be connected by the 1/2" aluminum tube which runs under the rack gear. The wires from the limit switches & steppers will run through there!
    Attached Thumbnails Attached Thumbnails 9x5_Router_624.jpg   9x5_Router_625.jpg   9x5_Router_626.jpg   9x5_Router_627.jpg
  13. #293
    Apr 2007
    8082
    Widgit, looks like you and I are about the only ones actively working on building something over the holiday weekend. I guess Labor Day time off doesn't get as much respect from us retirees.
    You're making really good progress considering the complexity of your design and the amount of machining needed. Looks really good.
    CarveOne
    http://www.carveonecncwoodcraft.com
  14. #294
    Quote Originally Posted by CarveOne View Post
    Thanks Carv'e,
    Like I said: "This morning I played in the shop for a few hours"
    This aint work :cheers:
  15. #295
    Apr 2007
    8082
    Lots of laughs, that's my take on it also. It's physically demanding sometimes but it keeps me going. I could find worse things to occupy my time with.
    CarveOne
  16. #296
    Ditto!
    This morning, I setup the mill to drill the holes in the plates. Because the two end hole locations are symmetrical, I was able to simply flip the plate over! The 3rd hole was off the vise, so I propped up the material with screw jacks!
  17. #297
    Now its time for some lathe work
    I have 6 parts, 3/4" diam x 3" long. So using a 3-jaw chuck, and a solid stop inside the spindle bore, I turned one end to .500" x .750" long. Next I removed the chuck, and setup the collet chuck. Holding the parts on the .500" diam, I center-drilled each part. Now I can hold the part between the collet & the live center point. Then I turned the end to .500" diam x .125" long.
    Next, I put a .1875" radius tool in the tool holder, and plunged into the part while moving side to side. This made the part look like a spool, and all that was left of the original diam is 1/8" on each end.
    Attached Thumbnails Attached Thumbnails 9x5_Router_636.jpg   9x5_Router_637.jpg   9x5_Router_638.jpg   9x5_Router_639.jpg
  18. #298
    Now I can assemble the parts and bring them to the welder! But first I have to stop by the Air-Boat shop, to get one of the plates folded to 90 deg.
    After welding, I will make strips of sheet metal to wrap the perimeter of the assembly. Then, they will also be welded. Its important that all wiring, be contained in dust & fluid free areas.
    When all the welding is finished, I will drill and counter bore 3 holes for #10 SHCS. Then the hole centers will be transferred to the gantry ends for drilling & tapping.
    Attached Thumbnails Attached Thumbnails 9x5_Router_640.jpg   9x5_Router_641.jpg
  19. #299
    The parts are back from the initial welding, and I have cut the next set of pieces on the band saw for welding!
    Attached Thumbnails Attached Thumbnails 9x5_Router_642.jpg   9x5_Router_643.jpg   9x5_Router_644.jpg   9x5_Router_645.jpg
  20. #300
    Today I worked on the x-axis slide, drilling & tapping the end holes. The top & bottom plates need to be dowel pinned in place, and attached with screws. So I setup the mill with my big angle-plate, dialed it in and clamped the part securely. The dimensions come from the center and the front of the part, so I used my edge-finder to set the DRO to zero in both axis. This did not take long, as there were only a few small holes.
    Attached Thumbnails Attached Thumbnails 9x5_Router_647.jpg   9x5_Router_648.jpg   9x5_Router_649.jpg
  1. Crazy Idea - converting Air Cooled spindle to Water Cooled
    By BanduraMaker in forum DIY CNC Router Table Machines
    Last Post: 01-20-2018, 02:29 AM
  2. Water cooled 2.2 KW Spindle water fitting
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 06:21 AM
  3. water cooled spindle vs air cooled
    By ken2010 in forum Chinese Machines
    Last Post: 10-21-2013, 06:03 PM
  4. 4-axis CNC-router, NEMA23 steps, Gecko 540, Water cooled spindle
    By Vaffel in forum CNC Wood Router Project Log
    Last Post: 10-18-2010, 08:54 PM
  5. Water cooled spindle need ???
    By BFcarbon in forum Commercial CNC Wood Routers
    Last Post: 03-04-2006, 10:05 PM
