587,415 active members*
3,547 visitors online*
Page 15 of 15 5131415
Results 281 to 285 of 285
  1. #281
    Jan 2018
    6
    Re: TB6600 drive from EBAY
    Got my TB6600 drivers from eBay. They were same as described here BL-TB6600-V1.2 D412.
    Heatsink with no thermal compound. Added thermal compound and changed R11 from 15k to 33k.
    So now I am on safe Vref. Max Vref value now is 1,87v. So I can get about 3A current.
    Tested all 3 drivers they seem to work well.
  2. #282
    Feb 2018
    4
    Hello.
    I'm looking to upgrade the drivers in my cnc machine. Going to use them at 2.1A / 34V unregulated PSU. Currently running drv8825 clones.
    Would like to have a suggestion from the experts here on TB6600 vs TB67S109AFTG drivers for this level of amperage.
  3. #283
    Apr 2013
    1899
    Quote Originally Posted by Dactyl View Post
    Hello.
    Go for DQ542MA drivers, one for each motor. Don't buy any 3 or four axis drivers and mostly, don't waste money on the Toshiba drivers. Of course, this is just my opinion, I am sure others will disagree.
  4. #284
    1943
    Hello.
    The TB6600 will have no problem with that voltage/current level. My experience with the TB6600's is they work fine, but it depends on what you want out of a driver. I still use the TB6600's on small projects that I don't want to invest a lot of money in, but for things where I want good performance and smooth trouble free operation I use these:
    https://www.omc-stepperonline.com/st...or-dm542t.html
    This is a driver made by Leadshine for stepper online and it works great. It is also pretty inexpensive at $35
  5. #285
    Quote Originally Posted by petsat View Post
    TB6600 analysis and suggested modifications.
    High All,
    After many hours of reading, testing and experimenting I gathered all data that apply to MY Tb6600 board, made all modifications to comply to datasheet suggestions and several modifications suggested by other members here!
    My verdict:
    It is a fine board to kill many hours in learning how not to design a board!
    Did this work before the mods? Sort of.
    Does this work after the mods? YES
    Did I make it reliable? No! I would not claim that! I would not use it for serious work!
    It was fun though and educational!
    I would say: buy it if you have time, knowledge and patience!
    Petsat
    Hi everyone,
    Firstly, thank you Petsat for the detailed document.
    I`m having issues with low torque at slow movements with HY-DIV-268-5A, I know the short RC time constant on TQ circuit is the problem.
    Petsat have suggested replacing the RC circuit 2k2 resistor by 250k to increase the time constant. I know it`s a dumb question, but can someone point which is the 2k2 resistor to be replaced? left or right on the image attached?
    Thank you!
  1. TB6600 Drive (different version)
    By Dave3891 in forum Stepper Motors / Drives
    Last Post: 04-20-2014, 11:22 PM
  2. Ebay tb6600 driver board wiring help
    By varunalau in forum Stepper Motors / Drives
    Last Post: 09-12-2013, 03:53 AM
