Very nice! Great to see it running under its own steam. Good luck with the ATC!
My suggestion is also using a component for a carousel toolchanger named the same "carousel", I programmed mine for Hurco MD1 VMC in couple of hours even with needed changes for the component. Just use component and remap M6 , read inputs M66 and set outputs with M64 M65
hello i just bought jnc 40m i have trouble to set up softwere mach3,, please help me thank you
Sent from my SM-J510UN using Tapatalk
Ok, here is the first chips Clint made on aluminum, Cam needs a few adjustments, and the spindle drive needs a few tweaks on the parameters as it's not holding rpm in the heavier cuts, hopefully just a parameter of our that needs a change. If you have any insights or experience here please chime in!!
Cut specifications are below:
https://youtu.be/8l_myyQX-cg
https://youtu.be/G3HQfUe6d4M
Good luck getting things dialed in. Looks like pretty solid machining other than the bogging spindle (and the slow non-retract connecting moves, but I think that's something to work out in CAM.)
I'm no VFD wizard, but if you've got no idea where to start, I think slip hz, winding resistance, voltage boost, hz boost are terms to look for.
Below are all of the parameters available to set in the drive. Admittedly, they were all at the default settings as seen here during that cut. Control is analog +/-10v speed control.
Anyone who knows which of these may effect the bogging please lend your wisdom and knowledge!
Sent from my QTAIR7 using Tapatalk
What is E03 currently set at. It would also be worth knowing how much the motor bogged in cuts. Did it loose 900 rpm and E03 was set at 900? Would also be helpful to know what E10 and E11 are.
Do you know if it's an induction or synchronous motor? If it's induction, the slip parameters should be set, if you can find a data sheet for the motor it might be on there.
If it's synchronous, the PI parameters are where I'd start, E30-E36. It almost sounds like it's not using any integral term, as that should cause it to catch up again after getting loaded by a constant amount (and possibly overshoot when the load goes away.)
It's not synchronous according to that data sheet. I would look into the slip settings as well, that data sheet actually has the info to calculate slip. At 50 Hz, unloaded a 4-pole motor will run at 1500 Hz. Slip is just 1500 - the rated speed. So should be somewhere between 34 and 48 if it's similar to those motors. I'd try changing the torque saturation back and try putting in a value of 30 or so for slip and work up from there.
Ok so after going through the parameters and setting everything up and making one changer to the torque saturation setting from 450 to 550, it seems the bogging is gone. Here is a test video of the same doc, woc, feed and RPM..
Tool - 1/2" 3 flute carbide endmill
WOC - 2.5mm(.0985")
DOC - 17mm(.6692")
RPM - 6000
IPT - 0.0056"
IPM - 100
https://youtu.be/QqJal72PLok
Ok, here is a short video of today's testing of the spindle power. As you can see some of the power is bumped back up but it still bogs in heavier Cuts now which may just be the power curve of the motor. We have a few settings left to change and we benchmark..
https://youtu.be/mfDMQpkqC2c
0.011" per tooth? That's not messing aroundLooks like fun!
for sure!!.. that is a healthy cut for certain, wouldn't hurt to have some more power in the spindle.. considering upgrading the spindle and spindle motor, from 5.5kw to 7.5kw and bumping the speed range up yo 12k rpm and new spindle to handle it. at the time of originally purchase the funds were not available for that upgrade, but maybe in a few months they will be. seeing as we process 90% aluminum it makes a lot of sense.
Sent from my XT1585 using Tapatalk
They look like GX16 connectors
Did you ever get a chance to check the runout on the BT30 tool hoolders you got from tool tree? I am looking at ordering a set of BT40.
