Hi Pete. Very happy to have your ideas, and I think you are spot on with your current thoughts of the way my mix is behaving. Cameron, I'm sure, would concur, as he has suggested to me that making my mix much stiffer may well reduce if not remove the effect that I'm seeing.
I'll repeat here that this may only be a problem while I'm trying to produce the test samples. Once I move on to produce the machine castings, with a much bigger cross section, I can stiffen up the mix without having the difficulty of getting it into the 1/4" mold opening I have at the moment.
My current resin has an sg of 0.8 and when the two components are mixed has a viscosity of about 600cps(I think, if I remember the spec correctly).
I shall keep with the spinning method, as this is what I'm trying to develop as an alternative to open mold casting.
My own idea right from the beginning was that building the machine structure from separately molded parts would enable the builder to use smaller components which would then be assembled with a similar mix.
(Experience gained with a successful production of a small cnc machine would then allow scaling up without much difficulty.)
In addition, the high G forces involved will replace the need in open casting for vibration to "liquefy" the mix to get it into all parts of the mold; will increase the buoyancy of the air bubbles, replacing the need for vacuum; and will bring the packing density in the outer layers of each component to the best possible for the particular recipe being used, with any excess resin, or even unburst air bubbles congregating on the inner surface.
Regards
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
