Likely from the leadscrew nut, are the antibacklash screws in the nut snug? and the setscrews securing the nut in the saddle?
Got her oiled up?
Hoss
Got her oiled up?
Hoss
http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
I'll double check the antibacklash screws and setscrews for the nut in the saddle. I DO have it oiled. Maybe not the best kind of oil.. I was told chainsaw bar and chain oil worked pretty good.. Although, the stuff is black as day after being on the machine for a while.. I get that stuff all over me when I'm working around the screws, tighting up the gib locks etc.
Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
If you haven't learned how yet, go look up on how to do a "Solid Sweep". It has limited functionality, but it's fun to see and it sounds exactly like what you're wanting to get a look at. You model the cutter in your part file and it lets you sweep it through the part leaving the cut. It will give you the radii hive8 was talking about in the process. Sorta like doing the CAM software's job for it, albeit the long way around.
Well, while waiting for my stock I might as well print out one of the parts just to see how it'll look on the mill.
Printing now and should be done by the time the ballgame is over.
It's first accessory will be my Dewalt aux spindle.
The bracket will also mate with the lathe toolholder.
Hoss
and is the Dewalt for engraving?
Eoin
I have some 1/8 and 1/4 shank endmills on order for it for milling as well.
Hoss
Hey Hoss, this will work with your 4th Axis.
This video shows how the MPG works on a Lathe, but works just as well on a Router.
Homemade MPG used on the Lathe.wmv - YouTube
You can download a PDF on how to make one here.
CNC Projects
Cheers
Bob Adams
Hi Hoss did you ever try this product, looks like you could control the spindle RPM for the router attachment... manual and also in mach 3.
www.SuperPID.com - Super-PID Closed-loop Router Speed Controller
Hive 8 - G0704 CNC Mill - 20 inch Telescope - High Resolution 3D Printer - Lasersaur 100W CO2 Cutter / Engraver
Hey Hoss a side issue here it's a Mach question... and I'd appreciate your help http://www.cnczone.com/forums/1109429-post344.html and sorry to side-track your thread...
Eoin
Hey Hoss,
If you get back into your 3D printing in a big way, I just saw this video and thought, "here's a project worthy of Hoss's skills! I'm sure he could trick this one up to be industrial strength!"
Of course it would need a turret as well :-)
[ame=http://www.youtube.com/watch?v=4rrh6Pl4vow&feature=related]Mini printable lathe V2 - YouTube[/ame]
cheers,
Ian
It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
Hi Hoss no need to answer my previous post I finally figured it out, and sorry to side track your thread.....
Eoin
Made the quill accessory bracket today, I'll powder coat it copper tomorrow.
The ID comes out perfect even with backlash comp when you take a finish pass.
Hoss
Hoss,
Nice work!
Is this bracket is designed to clamp to the portion of the quill sleeve that extends below the head? I figured that might be a good way to mount an auxiliary high speed spindle....
Meddle not in the affairs of Dragons - for thou art crunchy and taste good with ketchup!
Yeah that's what I had in mind.
I wonder if I still have all the pieces around to try this on there too.
http://www.hossmachine.info/projects...face%20grinder
Hoss
Sent out an update for the Phase 1 conversion with new plans using direct drive with a large oldham coupler (size "P") from Mcmaster with one hub threaded M16x1.5 to replace the stock screws top jam nut.
I ordered an M16x1.5 tap on Ebay from China for less than $10 shipped free.
Can also use the same and thread the pulley for the belt driven version so the leadscrew extension is not needed.
Hoss
That is exactly what i did for my leadscrew conversion. A note, I recommend the belt drive at 1:2 ratio, the direct drive for me at least would only go about 15-20ipm without stalling, the belt drive got it up to around 50ipm and the motor sounded a good bit healthier belt driven then the direct drive.
Just my experiences:
I was using Keling 570 stepper
5056D driver
48V PS 12.5A
Chris
Belts are more often than not always a better option. They have a tendency to reduce vibration and fix micrometer sized shaft offsets. I wouldn't go any other way, even with stock screws.
