Huzzah! An epoxy chemist!
I have learned from the wisdom of many on this thread and cnczone like lgalla and probinson and walter as well as reading many books and datasheets. There are some sophisticated epoxy users here but alas, I'm not one: I'm just a crazy engineer who decided he wanted to figure out this E/G stuff.If you can give me a bit of background on your objectives, I am sure I can give you some good and inexpensive solutions.
Obviously you are a sophisticated user of epoxies, and from the looks of your experiments are using high quality products.
So, Welcome aboard Bloefeld and here's the scoop:I am a big fan of pure Bis A or Novolac systems. Huntsman makes a line of jeffamine curatives and accelerators that create systems that yield numbers considerably higher than what you are showing here. I can give you some stoichiometry to work from.
It seems to me from the little bits of the string I have read that you are going to need some filler materials to help stabilize the material as it cures and to reduce the chances of stress cracking. You will also probably need to cure in heat and then do a post cure heat to get maximum performance from the materials.
I would really like to help out on this project, and if you can give me a small amount of background, I'm sure that I have some value to add.
Cheers,
Bloefeld
The idea is to produce a dimensionally stable epoxy mineral composite for accurately casting machine parts. Such work has already been done in the past by Studer in Germany and their patent expired a long time ago. Several folks here who preceeded my interest got this thread off the ground.
I've done a lot of research on the filler aspects and believe I have the correct data to get the filler loading up to between 88 and 92% if the mixture rheology doesn't become too horrible.
The epoxy on the other hand is more troublesome because there isn't a lot of good data to go on. There is one product on the market in europe only that is for this purpose Hexion 556 mineral casting epoxy. The datasheet is attached but Hexion said they won't market it here in North America.
The original formulation we started out with was reichhold 37-127 and 37-606 because it was cheap, slow setting, low viscosity (600cps) and readily available. This is a diglycidyl ether reactive diluted Bis A system with a hardener composed of Amino-Ethyl-Piperazine and a bunch of nonyl phenol. This stuff has flexural strength of about 10ksi and modulus of about 380ksi. The viscosity is a touch high compared to the hexion 813/3046 I just tested.
In general, I'd like to see an epoxy that has viscosity of 300-600 cps when mixed, a modulus of at least 500ksi, a gel time of about 6 hours. I'd also like it to be non-toxic enough that it could be supplied to our readership here on good conscience without creating superfund sites all over the country. . .
This link gives a couple of the more numeric comparisons I've made recently between the epoxy modulus and the needed filler percentage with quartz filler. http://www.cnczone.com/forums/showpo...postcount=3302
The Reichhold 37-127/37-606 and the Hexion 813/3253 combinations were suggested by the respective apps engineers.
The hexion engineer said that that combo is used in several of their customers machine grouts. The hardener is a reaction product of TETA and tall-oil. I've concluded that this hardener is not a real winner in this application.
One of the folks who makes E/G for a living said that they use isophorone diamine as their hardener. I don't even want to crack open the bottle of Vestamin IPD or the Hexamethylene Diamine I got from Evonik Degussa until I get a fume hood. I know however that Reichhold and Hexion both make IPDA adduct hardeners that appear to be much less toxic and corrosive so I'm hoping that one of these pans out.
I think that the Hexion or Reichhold Resins are probably about what we need but I think the hardeners we have leave a lot to be desired.
Having given the specifics of the epoxy, The idea is to use carefully sized mineral fillers to get the filler density up in to the high 80% range ensuring bonding and viscosity control with a combination of silanes from DUpont, titanates from Kenrich, fluorosurfactants from 3M, and deairing agents from BYK. I've written software using the works of French concrete researcher Francois de Larrard to predict the density to which a given aggregate distribution will pack. De Larrard claims that the model is good to within 3%.
Any advice would be appreciated by the large following here. I seem to recall somebody suggesting that the Jeffamines weren't going to be good for this but I don't remember the rationale and I haven't tried them.
Regards all,
Cameron
