Hoss has one that does not use pneumatic s he did it when he first got his g0704.
Ian said he was thinking of using a mist system, that needs air.
Ian you can get machines that can do a better job than what a surface grinder could ever do yes they are in the $1 mill range.
your machine should be able to do 50% depth of cut and 6% width if not more using HSM what you have in fusion.
learn it you will love it.
it has cut in half the machining times on my router, it still works good if you do a 150% depth of cut 75% width by mistake. a 100% depth by 75% width works very well with a 1/2 blunt cutter. if I did the same thing with vectric it would go up in flames.
Ian don't argue about cnc cutting you know manual not cnc
