Hi PoppaBear10,
Glad you're joining us. The good news is that the aggregate formula is pretty much decided. The bad news is that we're still working on the epoxy.
For aggregate, we've come up with this this is probably fairly close to optimum: see <A href=http://www.cnczone.com/forums/showpost.php?p=371354&postcount=2413> post 2413</A> for where this was originally suggested.
1 part #6 Agsco Brown Aluminum Oxide
1 part #4 Agsco Quartz
1 part #2 Agsco Quartz
1 part #2/0 Agsco Quartz
1 part 3M G800 Zeeospheres
1 parts 3M G200 Zeeospheres
(www.agsco.com for the aggregates listed and somebody like the Cary Company in Chicago for Zeeospheres)
For epoxy, so far Reichhold 37-127 and 37-606 have been tried by several folks. (Available from US Composites as Thin epoxy with the slow hardener). I've also tried Hexion 813 which is similar to Reichhold 37-127 with their amidoamine hardener( a no-go ) and IPDA which looks promising:
For Hexion 813 plus IPDA at 4.51:1 I'm getting a flexural modulus of about 440,000psi and a flexural strength of about 14,000psi which is better than any of the previous samples but by a small margin in some cases.
Consensus from folks like Tony on the thread as I have been able to determine is that we'd be better off with some like DER331 Resin from Dow which cross references to Reichhold 37-140 using Jeffamine D-230 and or D-400 hardeners. Tony's theory is that under vacuum, something as thick as DER331 will have no trouble wetting the grains. (There's a good chance that the the high viscosity epoxy on uscomposites.com is actually reichhold 37-140 but I haven't checked).
I'm a bit dubious about the thick stuff personally because making massive scale parts under vacuum is just not in the DIY agenda. There are also some warnings in B.W. Staynes' paper from 1975 about the thick epoxy making for a mixture that is not very workable.
I'm fairly certain the the Jeffamines are the right hardener to go with for DIY E/G due to low toxicity and excellent published performance numbers. I've had good luck with IPDA in a few experiments with resin alone but IPDA will eat the flesh off your hands and the paint off the floor if not handled with the utmost of care.
Chris aka crr has been ordering up some of the resins and hardeners for the DER331/Jeffamine experiment. I'm going to order some of the Huntsman equivalent to DER331 (Araldite GY6010) and the the Jeffamine samples tomorrow to get on with it. I've gotten sidetracked a lot lately losing several months due to work travel earlier in the year and then a couple of other projects and making a totally vacuum tight sample mold.
Other lessons:
Degassing at less than 29.5 inches of vacuum doesn't really do anything. I watched my epoxy just sit there with no effect until the vacuum chamber gage got above 29.5 inches. SO, going back to the discussion in <A href=http://www.cnczone.com/forums/showpost.php?p=301798&postcount=1373> post 1373</A> More than 29.5 inches is how much vacuum it takes to get to the center of a tootsie pop.
Eson,
I've been using silicone release Agent from http://www.mann-release.com/ At $6.00US a spray can, for Mann Release 200, I can't even begin to imagine a reason to try to improvise something. The dimensional change from the release agent was so small as to not disrupt the transparency of a glass-clear sample I cast.I wouldn't worry about the effect of a silicone release agent like this on dimensions. You'd be more likely to have a problem with an improvised one. I do feel however that a Poly Vinyl Alcohol or wax based release agent will mess up part dimensions because it's possible to build up a pretty thick later of PVA or wax.
