Also still have a 40x48 or 40x60 Predator machine in stock like one in video
PredatorCircleProgram - YouTube
XZero cnc
So more pictures of the predator for those who are thinking about it. Easily cutting aluminum in a vise or on the table top.
30X48
Attachment 211406![]()
XZero cnc
New 4th axis , 5 to 1 reduction ,3 inch jaw or 4
Attachment 211414![]()
XZero cnc
Have free shipping to USA only on Raptor machines
http://www.xzerocnc(dot)com/forum/sh...ptorXZ-pricing
XZero cnc
Venom machine will have the extrusion extruded second week in JAN.
Also extrusion for a V-groove low cost machine with Thomson rails and 80x80 aluminum . No bolt on steel plate . Belt drive, or ballscrews .
Will be selling extrusion on their own also for the DIY-ers
XZero cnc
Uprights for Venom are 10 inch wide,3 inch thick and 8 inch wide bolting to backing plate . It is going to be a heavy duty machine.
Casted and machined all in Canada
XZero cnc
This was what the first drawing was. But could not get it done in North America
Attachment 213618
After 5 new drawing, this is the final. 0.0125 at 12 feet for flatness with out machining
XZero cnc
Now have the Leadshine MX3660 and Nema 34 or 23 motor kits for the Venom machines
Attachment 213684
Features
Power up to 3 stepper motors of NEMA 17, 23, 24, or 34
Sophisticated stepper motor control based on the latest DSP technology
Built-in breakout board and I/O’s
Step & direction Control
200 KHz maximum frequency for each axis
20 - 60 VDC supply voltage
1.45 - 6.0A output current per axis
8 micro step settings: 1, 1/2, 1/4, 1/8, 1/10, 1/16, 1/32, 1/64
8 output current settings: 1.45, 2.08, 2.72, 3.37, 4.05, 4.72, 5.35, 6.0 A
Damping and anti resonance
Allowing individual output current & micro step settings for each axis
Input pulse smoothing for less jittering, higher torque, and quicker response
Extra low motor heating & noise
Extra smooth motor movement
Simple micro step & output current configuration via DIP switches
Fault output
Compact size and easy setup
50% automatic idle current reduction
XZero cnc
Anyone looking for 4 inch longer z axis plates for square railed Z axis send me email. Help for smaller spindles other than tekno.
Also 12 inch travel Z stock on new 60x65 Demon machine,but have a few extra just Z axis for using 6 or 7 inch end mills
XZero cnc
Will have info up shortly on low cost 60x60 XZ Eliminator , 20mm Rails and with ballscrew, not low budget v groove bearings or rake and pinion
XZero cnc
They are not done yet, but same as my first support rail machine with lots of changes and bigger rails and frame .Also 58 inches wide Attachment 219030![]()
XZero cnc
Look nice.
If I could, I would change mine for a predator with spindle...
Envoyé de mon HTC One en utilisant Tapatalk
Both Demon and Eliminator both have single or dual ballscrews, Eliminator is about half price compared to Demon.
XZero cnc
Any way to change my Viper X2 into a supported rail on the X axis?
Also how is the 3D printer/milling machine coming along?
Mike
