587,762 active members*
3,745 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Dinosaur skeleton, and other models, DXF files.
Page 1 of 176 1231151101
Results 1 to 20 of 4471
Hybrid View
    Feb 2004
    2337
    Does any one have some dfx or gcode files for a dinosaur skeleton or a bridge or a rocking horse?
    If you do and are willing to share them could you please upload them to this thread.
    Similar to these Dinosaur Wood Skeleton Model Kits Replicas, Collectibles
    Being outside the square !!!
    Apr 2003
    470
    Funny... me and my kid put three dinosaurs together just 3 days ago... we even did the Raptor that you posted...
    If you buy a model there is a drawing on the back shoing the all of the parts. You could scan (Or maybe you have a buddy that would) that drawing and retrace it and modify the slots for the material thickness that you are going to machine.
    Nathan
    Sep 2003
    363
    A guy over at ShopBot did a few of the big dinos.
    Jul 2011
    Tractor kits...............
    Hello friends
    research tractor kits
    Please file in pdf format
    Thanks for the help
    Enzo from Italy...........
    Apr 2011
    ciao Enzo.
    Potresti spiegarmi come si arriva ad un dxf partendo da un pdf?
    Quale programma usi?
    Grazie
    anna
    Nov 2010
    English please
    Feb 2004
    150
    I'm looking for a dxf file of a dinosaur as well. I'm want to build one for a community center that will be opening up in a few months, my boss suggested something special.
    -Patrick
    _____________________________________________
    measure twice, cut once - a good rule for everything
    Aug 2003
    318
    I bought one of the small dino wood kits from Harbor Freight for $1.00. I took the line drawing and scanned it in and used Artcam to create a model. Too bad artcam doesn't export as a dxf. I would post it if it did. Took quite a while to clean up the vectors but came out good..
    Dug around and found some dino fonts. You just put them in your font folder. Then go into your cad program and add text. select the dino font letter. Read the txt file for the list. Wala you got all the parts. They are designed so that you use the thickness wood of the bit you are cutting. So 1/2 bit would be 1/2 wood. They could use alot of work but should get you going. If anyone cleans them up I would appreaciate you posting the new font or dxf file to the download section so everyone could use it.
    Donny
    Attached Files Attached Files
    Feb 2004
    2337
    Thanks Whiteriver. I can see the "Fonts"
    Was there the slots where you put it all together, or did that get lost in the scanning?
    Is that what you meant by cleaning them up?
    Maybe if you posted the Artcam files someone might have a conversion tool that will make them into dfx files.
    Apr 2008
    125
    Skelett
    My Human skelett
    Apr 2003
    1876
    Benny, I think I put an iges file of a shark on the downloads page. Have a look when Paul gets it up, ( ) or I'll email it to you if I can find it again.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Robot Graphic File
    Here is a Robot Graphic File I Made.
    Also some examples of it Engraved on Arylic and placed on LED light box.
    Short post I did with other LED Acrylic Samples
    http://www.cnczone.com/forums/portfo...led_signs.html
    Can down load it at link below
    Download Robot Graphic Click Here
    Feb 2004
    150
    I was wondering if we could have a specific spot on the forum for trading files like the dinosaur file? It would be great to pick up plans for clocks, dinosaurs, carved wood panels, etc... all from one location. I've seen it on the artcam site, would it be possible to do the same here?
    -Patrick
    Feb 2004
    2337
    Pat if you look in the downloads section you will see a few items.
    It would be great if every one did join in and upload a few things though.
    I suppose we can only lead by example.
    Apr 2008
    125
    Slots manual
    With files where only the slots with lines are make I the slots manual in Corel X 3 clean and it from it in DXF files
    Dec 2009
    ship
    this is work in corel draw x 4.
    Dec 2009
    Quote Originally Posted by ampoursha View Post
    ok?
    I can't open the file. I used CorelDraw Paint Shop but still no result. What program should I use? Or if it's not too much work for you can you provide dxf file
    Dec 2009
    Quote Originally Posted by Bi4kia View Post
    My English is not very good. But i can understand your texts.
    ok, This file has many problems. If you can fix it
    Sep 2007
    8
    Do you have a finished photo?
    Apr 2008
    125
    Fliege
    3D-Puzzle
    Material 3 - 5 mm FoamSheet
    Route 66 is Speckstone
    Attached Thumbnails Attached Thumbnails Drache4.jpg   Biene_A.jpg   Grille1.jpg   SA_A.jpg
  1. Dinosaur Puzzle
    By Rosey Musick in forum Machine Created Art
    Last Post: 04-11-2013, 07:03 PM
  2. Dinosaur Trade
    By roninB4 in forum Diemaking / Diecutting
    Last Post: 11-18-2012, 03:01 PM
  3. Who will stop this china Dinosaur??
    By smtclman in forum News Announcements
    Last Post: 12-19-2010, 11:05 PM
  4. Epoxy Granite "s Skeleton
    By hkxy in forum Epoxy Granite
    Last Post: 05-03-2010, 02:35 AM
  5. Replies: 2
    Last Post: 03-09-2007, 08:47 PM
