588,215 active members*
3,968 visitors online*
IndustryArena Forum > Mechanical Engineering > Epoxy Granite > Epoxy-Granite machine bases (was Polymer concrete frame?)
Page 182 of 253 82132172180181182183184192232
Results 3,621 to 3,640 of 5053
  1. #3621
    Jun 2006
    82
    infusion?
    Hi
    Jestah... long time lurker first time poster, well in the thread any way. I have recently started to build my own cnc shaper when i stumbled across this thread and im hooked!
    well i was hooked until about the 2nd hour of reading posts! While i have given a good attempt to read the thread please excuse me if i ask something already covered.
    First up could some one tell me how big the largest home build table using E/g has been? I am guessing that having a vibration table is a big limiting factor to size. Has any one managed to bond smaller blocks together to make a bigger overall size.
    I understand the basic process of mixing resin with the granite but has any one attempted to use a technique like resin infusion as it seems to me that this could be a really easy way to get a very good resin ratio.
    Resin infusion is a process were a composite part is layed DRY into a mold and then assembled with a resin feed tube that dumps the resin into the mold, you transport it around the mold using a mesh that allows the resin to flow very fast and then to the part where it penetrates any voids. I would think you could do the same, although having an even compaction would be essential to even resin flow, by packing dry aggregate into a mold, settling on a vibe table and then vacuum bagging and infusing.
    How accurate are people pouring a table surface as i would like to attempt this some day but can not afford the tooling to mold the size table i would like. I have seen a few smaller table surfaces done with low viscoity epoxy poured onto the centre of a large table but could not find much information about it. Could any one recommend a post to check out.
    thanks in advance
    Jestah
  2. #3622
    Apr 2007
    777
    Hi Jestah and welcome.
    The first important answer is that none of the DIY-ers have made more than test pieces. No tables produced yet that I am aware of.
    The second is that without vibration and careful aggregate selection, it would be difficult to get a stiffness much beyond that of pine. An E/G table with a low fill rate would be more dimensionally stable than wood and likely flatter however. From the academic papers, it looks like the aggregate needs to be carefully selected and vibrated at above 2g to get commercial quality material that which is much stiffer than pine.
    The flat part of the table will be as flat as whatever you cast it on. I don't think that our number here have actually done the epoxy surface plate experiment yet but it should be possible to get .0002 per foot which is more than adequate for a router table.
    In short, E/G is a nice material but to get rigid structures suitable for metalworking tools, the tools required to make the part are probably more expensive than the part unlike we had hoped.
    For routers, it should be possible to use home shop grade low modulus E/G material but nobody has gone through the work to try it yet. Most of the diehards here on the thread like me are trying to perfect a commercial grade material as opposed to just building something.
    Regards all,
    Cameron
  3. #3623
    Apr 2006
    225
    I was wondering in an alternative to vibration tables we use this concrete vibrators
    http://www.laku.com.my/Concrete%20Vi...le%20Frame.jpg
    The picture is too big so I posted the link
    Have anyone tried?
    They are kinda cheap alternative and you can rent one for a couple of days in some places... Does it work?
  4. #3624
    Jun 2006
    82
    I am keen to join the cause
    Count me in! I work for a firm that makes prototype carbon fibre parts and we would like to join the search to make a stable table.
    Could some one point me to a website or post with some info about vibe tables as i think i need to understand more about the compacting. In my limited knoloage it seems to me this is the biggest thing holding back the diy build.
    What do you guys think about this idea:
    build an mdf torsion box to create a flattish casting surface, skin it with a thin released al skin to make it air tight, build in any need features, fill with DRY granite, infuse, demold and fill any exposed thread/mounting holes with wax, build a small side wall and pour a very thin low viscosity slow cure epoxy and then put in our autoclave and spin up the vac pump to degass any air.
    I want to do it this way as i have no access to a decent flat table to make a flat casting on. We have a 3x2.5m al plate but it is not very flat -/+ 2-3mm over its length.
    also has any one tryed steel ball bearing of the right size so each fit in the gap of the lager one above? it seems this could be a solution that may need less shaking?
    Is there any way to search a single thread?
  5. #3625
    Sep 2007
    9
    Hope you like this document guys.
    Attached Files Attached Files
  6. #3626
    Apr 2007
    777
    Quote Originally Posted by jestah View Post
    Great. Several of us have the idea that a mold for a table could be made by casting a slick of low viscosity epoxy with a deairing agent. This will be good to about .0002 in/ft or the curvature of the earth. Precision Epoxy http://www.precisionepoxy.com/ makes epoxy commercially used for making plates on the floor for aligning car suspensions.
    To make a cast plate, one will have to get a flat surface perhaps by the self leveling epoxy method and then make a mold and cast a more substantial plate against the flat surface. For a small plate, this will work but for a truly large plate, .0002 in/ft might not be accurate enough.
    Quote Originally Posted by Jestah
    I don't think anybody here knows if a fully compacted mass of powder can be vacuum infused or not. I've successfully vacuum infused a very loose packed mass of particles with epoxy but that doesn't scale to a tightly packed mass.
    In general, Steel shot is more expensive than other fillers and the friction between the randomly oriented balls means that it is just as difficult to compact. It also does not achieve Face Center Cubic structure like the fitting balls into the voids of the larger balls idea would hope.
    The models suggest that optimally one needs at least 4 orders of magnitude of size difference between the smallest and largest particles and for 4 orders of magnitude, and 8 carefully selected intermediate sizes between the largest and smallest.
    Vibration is the most difficult part for the underequipped and from the research from several places, the part appears to need to be vibrated at at least 2g to compact fully.
    The search this thread tool on the right side of the page up by the thread numbers does a passible job. If you are a linux user, I have written a couple of scripts to download the entire thread so I can search it with grep. I've also written some code that allows me to link to posts by post number which I used to make the index thread. If anybody wants to update the index, I'll share my tools with them.
    Jestah, Take a look at the links on pg 301 to get a bit more idea of what's going on.
    Regards all,
    Cameron
    P.S. Thanks to MBK for the post on optimizing the EG spindle.
  7. #3627
    May 2009
    30
    YOU CAN BUY TURCITE AT Toll Free: 888-887-2483
    Email: [email protected]
    THE MACHINE TOOL GROUP
  8. #3628
    Jun 2007
    Epoxy Granite filler
    Article in the most recent 'Model Engineers Workshop' magazine.
    This involved a project to reduce chatter on a small (X1) mill.
    Part of this was to fill the hollow column with epoxy granite to add mass and as a dampening medium.
    The outcome was very positive with a very heavily damped column which had not vibration problems and which reduced chatter markedly on this light mill.
    Might be of interest, not as a bed or solid mass of a machine tool but to add mass to one.
    John
  9. #3629
    Apr 2007
    777
    John,
    Thanks for the reference. I've asked a friend with a subscription to let me borrow the issue when the mail scow finally lumbers across the pond.
    I'm still actively working on this but most of what I'm doing right now is work on my lab infrastructure which means very little actual research gets done presently.
    Regards all,
    Cameron
  10. #3630
    May 2009
    12
    Epoxy Granite
    There have been and are many commercial manufacturers of so called "epoxy granite". Hardinge started back in the late 80s. Taylor Hobson at the same time and Philadelphia Resins a little later.
    Currently Anocast, Philadelphia Resins, Granitek, etc all provide epoxy granite machine bases
    I have designed epoxy granite bases for almost 20 years for ultra-precision machine tools and have never put reinforcement in the bases
    Be careful about full cure of the mixture
    Typically there is only 8% or so of epoxy to aggregate, so cure time should not be an issue
    Be careful of outfits that put more epoxy than 8%
  11. #3631
    Jul 2003
    586
    by weight or volume?
  12. #3632
    Jan 2008
    25
    and why its bad to have more than 8% of epoxy ?
  13. #3633
    May 2009
    12
    By volume.
    As for Alex, if you think about it, the physical properties of natural granite (and diabase) are a function of its makeup - quartz, feldspar and mica. If we introduce plastic (epoxy) in any large quantities, we greatly compromise why we are choosing granite - 8% by volume has been shown to yield as close to natural stone as possible
    The epoxy acts as a bonding agent and only a bonding agent. The aggregate is sized and shaped so intimate contact is insured between the aggregate particles themselves - the epoxy filling only the voids. This simulates mother nature - almost
    Some companies use only quartz, while others use a combination of the three main granite constituants - It has been my experience that there are really three things that you MUST look for in an epoxy granite manufacturer:
    1. Mold making expertise (pre-production and production) - some molds start out as wood for pre-production, yielding perhaps 5-10 machine bases - then migrating into aluminum
    2. Vibration Table - as the mold is poured and begins curing, it must be vibrated to insure aggregate contact, complete filling of the voids with epoxy and no air pockets - for some large machine base molds, the vibration table must be quite large to accomodate the mass
    3. Metrology and fixturing - because epoxy granite yeilds itself to "casting in" features such as threaded inserts, mouting plates, drainage piping, electrical chaseways, etc., the company producing the base must exhibit the ability to place and insure placement of all of these features
    Finally, epoxy granite bases do not replace natural granite bases. Natural granite (or diabase) still reign as the most stable platforms for ultra-precision machine tool and metrology bases.
  14. #3634
    Jul 2003
    586
    thanks for the by volume.
  15. #3635
    Mar 2005
    1673
    Hi jonixlic,
    Just want to say thanks for your input and welcome to the zone
    Regards,
    John
  16. #3636
    Jan 2008
    25
    Quote Originally Posted by jonixllc View Post
    By volume.
    I agree with you, but also have my own opinion
    All that you say is appliable only if you use right mix of sands. If you have some disbalance (for example low quantity of micro size sand), in case of hobby its possible, than youll get voids, because of small amount of epoxy, and final result will have poor quality.
    But if you add more epoxy and use vibration - all corns will fit together with minimum distance between each others and extra epoxy will be on the top of form, where you can remove it. All what i say is based on my own experiments.
    PS: sorry foy my poor english.
  17. #3637
    Jan 2008
    25
    help needed
    hi all!
    I need some help:
    meybe some one know links to seller/manufacturer (in EU) of insert nuts applicable for epoxygranite ?
    I had one but lost link and cant find it any more
    Thanks!
  18. #3638
    May 2009
    12
    Quote Originally Posted by alex_ku View Post
    hi all!
    I need some help:
    Thanks!
    Contact: [email protected]
    It is located in the midlands, specifically the Leicester area
    They used to be the main supplier of epoxy granite bases for Taylor Hobson metrology products as well as Taylor Hobson's line of ultra precision machine tools
    Derek Robinson used to be the Managing Director and has good experience in epoxy granite
    If they cannot provide you with an EU manufacturer, I can give you a US manufacturer
  19. #3639
    May 2009
    12
    Alex-
    Your english is OK
    You are correct - the correct size of aggregate is of high importance
    For most manufacturers, this is what is proprietary in their process
    For most ultra precision applications, achieving a base that's as close to natural granite is the goal -strength, mechanical and thermal stability and good damping characteristics
    Although epoxy granite has its limitations, manufacturerd properly it also has its advantages
  20. #3640
    Jan 2008
    25
    Thanks jonixllc! Waiting for an answer
    I prefer an online shop, but we will see.
  1. Replies: 71
    Last Post: 08-25-2020, 01:18 PM
  2. Replies: 14
    Last Post: 11-13-2015, 02:57 AM
  3. Replies: 9
    Last Post: 01-15-2014, 11:39 AM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. Epoxy-Rice Machine Bases (was Polymer rice frame?)
    By mdierolf in forum Mechanical Calculations/Engineering Design
    Last Post: 11-02-2008, 04:16 AM
