There is another less complicated Mammoth DXF in a ZIP file on page five of this thread, post #56.
http://www.cnczone.com/forums/attach...9&d=1131204004
to giuseppi
reference: bird
maybe this is a cardinal
bird: "http://www.lobzik.pri.ee/uploads/newbb/3227_5291fec48c90d.jpg"
Hi yauco. I don't think so. A Cardinal is distinguishable by the feathers on the top of the head. However, I might be able to modify and add the topknot to the file you posted
Here's a pic of a Cardinal.Attachment 262966
Instructions (use pic as ref):
First, the body with the slot, next the body with the hole next to the beak.
Next, the part that looks like a swan, then the legs.
Insert the piece with the wide slot through the bird, slots to the rear.
Finish with the feathers, large, medium and small, then the slotted feather.
Repeat for other side.
The tail, from the bottom: large to small.
Attach the part to the bottom of the legs.
You'll end up with one extra piece, I don't have any idea where it goes (part that goes through slot of body).
Here's a DXF of the Bird file yauco posted earlier.
HI,
Does anyone has this file in dxf ? (mammoth)
ho and
Happy New Year and good decoupe to all :banana:
great work
my bad english izletenadamqgma from you to help us
CAN ANYONE UPLOAD SOME DOLLHOUSE DFX FILES
Scroll up to the top of this thread. Below the page numbers find the Search Thread button and click on it. Type " Doll House" without the quotes. Hit enter. You'll have to look through the pages but there are several to be had. In a couple minutes I found two.
g
hey i need valentine gifts dxf thanks
Attachment 265292
hey any one have dxf file for this wooden heart thanks
Make A Box
This is an online utility that lets you create boxes! You can edit all parameters, very good (Translated by google)
[hola tendras de casualidad las instrucciones para armar el cavalo alado? no se si le faltan piezas o no lo entiendo.
creo que yo tengo un leon, tengo que fijarme si lo tengo te lo paso
muchas gracias
hay eso me encanta, usd. lo consiguio? si lo tiene me lo podría intercambiar por algo que yo tenga y usd. nececite??
gracias
