587,192 active members*
2,364 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Upgrade of Huanyang vfd
Page 19 of 19 9171819
Results 361 to 378 of 378
  1. #361
    ericks Guest
    Re: Upgrade of Huanyang vfd
    If you require more help then just let me know.....i am at work atm, when i get home i can set mine up and send you images
  2. #362
    Jun 2017
    238
    Quote Originally Posted by ericks View Post
    I've ordered the probe but just thinking of how to do it right before it arrives. I like the idea of including the led to the probe.
    Sent from my SM-G935F using Tapatalk
  3. #363
    ericks Guest
    Adding a led would be easy...
  4. #364
    Jun 2017
    238
    Ordered a pre-wired led with the resister already attached.
  5. #365
    ericks Guest
    Do you have a soldering iron? in case you need to change the resistor value
  6. #366
    Jun 2017
    238
    Yup.
  7. #367
    ericks Guest
    Okay....great. When do you expect your probe to arrive?
  8. #368
    Jun 2017
    238
    Hopefully within the week but sometimes it comes from China and takes longer than expected.
  9. #369
    Jun 2017
    238
    Led info....
    3mm constant/flashing pre-wired LEDs with 12v resistors & optional black plastic snap-in holders/bezels
    Lens Type : Water Clear
    Lead Length :*20cm
    Optimum Supply Voltage :*9v - 12v for highest brightness
    Minimum Supply Voltage :*5v with much reduced brightness
    Maximum Supply Voltage :*14v*
    Current :*20mA @ 12v
    Viewing Angle : 20~25 Deg
    Flash Rate : Approx 3 per/2 Sec*
    I bought non flashing.
  10. #370
    Dec 2005
    600
    Guys, don't want to seem to be a spoil sport here, but you're burying the original topic of the VFD with chit-chat and other topics that are better off being asked in the other forums that are set up to handle those kinds of questions. It makes it hard for folks who have spindle/VFD issues to have to wade through the chit-chat fluff (which is better handled through private messaging) and posts like touch off probes which are better handled in the electronics forums or the software forums like the Mach Software forum.
    Please try to stick to the original topic.
    Mark
  11. #371
    Jun 2017
    238
    Quote Originally Posted by wendtmk View Post
    Mark
    I agree we did go a bit off topic but the information contained in this topic is specific to the using the same vfd and Bob and getting mach3 to work with these specific components. At least if anyone else chooses to use these components they will have the information in one place/topic. I understand that it's best practice to use different topics but I've yet to find a topic that doesn't veer off occasionally.
    As most of the posts were between ericks and I there didn't seem to be an issue.
    Great help is sometimes hard to find and this forum is very helpful. I understand your point of view.
    Thanks Jase
  12. #372
    ericks Guest
    Maybe best then you start a new Thread for this Five axis breakout board in the general cnc electronics forum?
  13. #373
    Jun 2017
    238
    Possibly....
  14. #374
    ericks Guest
    Otherwise we can do it by email
  15. #375
    Jun 2017
    238
    I'm still at work but I'll sort a thread.
  16. #376
    ericks Guest
    No worries....whatever you prefer.
  17. #377
    ericks Guest
    Jase....please empty your messages, i am unable to msg you
  18. #378
    Jun 2017
    238
    Ok no probs
  1. Huanyang VFD
    By lt00273 in forum Chinese Machines
    Last Post: 09-13-2017, 04:55 AM
  2. Huanyang VFD
    By lt00273 in forum Spindles / VFD
    Last Post: 09-07-2017, 06:10 PM
  3. Huanyang 2.2kW VFD.
    By atc40 in forum DIY CNC Router Table Machines
    Last Post: 10-19-2014, 04:33 PM
  4. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  5. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
