588,665 active members*
6,209 visitors online*
Page 2 of 3 123
Results 21 to 40 of 53
  1. #21
    Feb 2006
    7063
    Re: 440 Power Drawbar
    Quote Originally Posted by kstrauss View Post
    Looks good! I need some of that track for my machine...
    It's usually called "drag chain", and is available in many sizes on E-Bay for next to nothing.
    Regards,
    Ray L.
  2. #22
    Aug 2015
    368
    Foot petals coming in today, I'm stoaked! I was looking for a nice foot petal, but noisy of them are cheap pos's and most need to be wired up , just lid of things I didn't like about a bunch of different ones...I finally found a great company, they are supposed to be the best, the petal is really nice and it will be all wired up ready to go. I'll post pics and I'll shoot a YouTube video of the whole thing tonight.
    Sent from my SM-G900V using Tapatalk
  3. #23
    Aug 2015
    368
    Here's the complete video:
    https://youtu.be/AxnHQgmhqeY
  4. #24
    Aug 2015
    368
    Happy Thanksgiving Everyone! I hope your spending done time out of the shop with your families. Parts will be landing this upcoming week, as soon as they are all in I will have your PDB's in the mail. I'll let everyone know when they have shipped and send tracking info.
  5. #25
    Aug 2007
    701
    440 Power Drawbar
    I love the function but I wonder how much force this single stage air cylinder applies
  6. #26
    Aug 2015
    368
    Quote Originally Posted by brianbonedoc View Post
    It's enough, quite a bit overkill actually. When I started figuring this out my minimum requirement was that it would compress the washers from the stock Tormach 1100 PDB, the washers I'm using hold more than the ones the 1100 does.
  7. #27
    Aug 2007
    701
    Good to know! How many bellevilles and what rating are they?
    Sent from my iPad using Tapatalk
  8. #28
    Aug 2015
    368
    This is the 1100, I'm pretty hard on it, and pull out isn't something I could tolerate. The Belleville washers being used in this video are not as strong as the ones I will be including with the kit. I just left the shop, I'm not sure about the rating but they are a significant amount more than these. This is aluminum, 3fl Tormach CrN Coated EM cutting at 5000 RPM, 0.1WOC, 0.4DOC, @70 IPM. . That's my standard production recipe for that half in cutter, it runs 36 hours at a time, no pull out.
    https://youtu.be/NzLOQUK3FmA
  9. #29
    Aug 2007
    701
    Beautiful work tbev!
  10. #30
    Feb 2006
    7063
    Quote Originally Posted by tbev View Post
    I'm really struggling with the math here, simple though it is.... That appears to be a 3" air cylinder, which means a single piston will provide only about 700 pounds force at 100 PSI. Even if it's a triple-stage cylinder (and it does not appear long enough to be triple-stage), that's still only 2100 pounds maximum force. Actual drawbar tension when holding the tool will be considerably lower than that, as maximum force is required when releasing the tool. The Tormach PDB provides ~2500# maximum drawbar tension, and still often suffers from pull-out, per some reports here. So, how can you possibly be providing higher drawbar tension than the Tormach with such a small cylinder?
    Regards,
    Ray L.
  11. #31
    Oct 2011
    477
    Quote Originally Posted by SCzEngrgGroup View Post
    I was having the same thoughts. The static calculations do not smell right.
    The PDB on my 1100 works okay most of the time. It is kept well lube with Nuclear Grade (long story from my sorted past) Pure Nickel Never-Seize and adjusted very tightly. The opened drawbar will just allow the TTS holder slide in and out with drag at the expense of an occasional pair of Nylon Bolts on an ATC Finger (McMaster-Carr in a bag of 100). PDB is operating at 115PSI.
    The pullout only seems to occur when the machine is pulling near max horsepower on the load meter and encounters some squeal or chatter. I believe that the holder must first slip in rotation breaking the static friction lock holding it in place. Once this slip occurs, especially in the presence of vibration, the holder just screws out of the collet. This increases tool overhang and breaks contact with the TTS flange worsening the chatter and increasing the slip. I do not believe that the lateral force along exerted by the helical angle of the cutter is sufficient to pull a tight holder out of the collet, not at the power levels available on the 1100.
    Is it possible that the single cylinder, with it much lower force than the triple 1100 cylinder, works simply because the lower powered 440 does not have sufficient power the slip the TTS holder in the collet?
    Gary
  12. #32
    Feb 2006
    7063
    The 440 spindle is lower power than the 1100 - 3/4HP vs 1.5 HP. And the cut he describes on his 1100 (3-flute 1/2" Carbide EM in 6061, 5000 RPM, 0.1"WOC, 0.4"DOC) is only about a 0.84HP cut, so below the power where pullout would be an issue even on a rather poorly adjusted Tormach PDB, but still beyond the capability of the 440. So, still does not really compute...
    Regards,
    Ray L.
  13. #33
    Aug 2015
    368
    I understand what your saying. The easiest way I can explain it is that the single cylinder on the 440 PDB compresses my factory 1100 Belleville washers. That leads me to believe the holding power of my 440 PDB, using the Tormach washers, will be close to that of the factory 1100 PDB, which is more than enough for a machine with what, half the HP.
  14. #34
    Feb 2006
    7063
    Sorry, but that logic simply does not hold water. The design target on the Tormach PDB was 2500# drawbar tension. The release force is even greater, and requires compressing the springs to almost flat. A single stage cylinder operating on 100PSI simply cannot provide anywhere near the force required to do that. That is simple, basic physics. The 440, with a 0.75HP spindle, clearly requires less drawbar tension that a 1.5HP 1100, so you likely need something more on the order of 1250# for the 440 to provide performance comparable to the PDB on the 1100 (and the 1100 is not immune to pullout). But your air cylinder provides barely half that force. This is an area I know a little about, since I design and manufacture power drawbars and toolchangers for TTS systems, and I've done extensive testing over many years to develop a TTS PDB that never, ever suffers from pull-out on 1.5HP machines. My PDB provides ~3500# drawbar tension, by actually torquing the stock drawbar to 30+ ft-lbs, without using any Belleville springs, which is why it's unaffected by chatter. I can tell you from my own testing that what you have may "work", but will not be truly robust, as the math simply does not add up. Add in chatter, and I can pretty much guarantee you will see pull-out. A 3" 3-stage cylinder will get you where you really need to be if you want it to be absolutely bullet-proof.
    Regards,
    Ray L.
  15. #35
    Oct 2011
    477
    Please don't misunderstand my comments.
    I think that this is a good looking, functional drawbar.
    gary
  16. #36
    Aug 2015
    368
    I don't know what else to say besides I'm using it, it works. I'm not trying to make a bunch of money, I'm simply not going to deal with manual tool changes, I spent a lot of time a money figuring out the best setup. If it was giving me any issues I certainly wouldn't be selling them to anyone else. The issue I think your having the most trouble with is assuming it's a 3in cylinder, it's also not some chinese built piece of **** cylinder. I'm having them custom made, but the fact of the matter is it makes more than enough holding power. I sold 14 of them and a couple people at least will probably make videos or at least provide feedback. Again, if I wasn't sure everyone would be more than happy with their performance I wouldn't be selling them.
  17. #37
    Apr 2013
    1788
    What is the cylinder size? A 4-inch cylinder would supply 77% more force than a 3-inch one.
  18. #38
    Feb 2006
    7063
    Which would put it exactly in the range I suggested for that machine....
    Regards,
    Ray L.
  19. #39
    Jul 2004
    1424
    Congrats. That's awesome.
    I would suggest that you offer Tormach to let them sell your drawbar (which is how some of their other mill accessories came into existence), except I am sure that they already have a design in the works from the company that makes their other PDB. Hopefully for you, it will be as slow coming to the market as many of their other accessories.
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
  20. #40
    Aug 2015
    368
    Regards,
    Ray L.
    Yup. I hope you know I don't take offense or mean to be rude at all. I'm always down for constructive criticism and I've always appreciated your thoughts, and all the help you've given me in the past.
Page 2 of 3 123
  1. 30Taper YCM30 Drawbar or power drawbar options.
    By countryguy in forum Knee Vertical Mills
    Last Post: 12-28-2014, 06:15 AM
  2. Power Drawbar Help Please
    By cadguy247 in forum Benchtop Machines
    Last Post: 08-20-2014, 07:22 PM
  3. Power Drawbar
    By David Da Costa in forum Novakon
    Last Post: 07-13-2010, 04:20 PM
  4. Power Drawbar Anyone?
    By gleas in forum Novakon
    Last Post: 07-20-2009, 01:34 AM
  5. power drawbar
    By fourperf in forum Bridgeport / Hardinge Mills
    Last Post: 03-22-2006, 03:28 AM
