587,935 active members*
4,225 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc alarm on a 0-MD control. Yang SMV 1000 machine.
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    24
    THX
  2. #22
    24
    I'm so close to having this thing fixed......
    I have the Rotary table problem figured out. A wire was sitting on the bottom of the control that was supposed to be hooked into pin 25 of the M20 plug on the Fanuc I/O board. The Rotary table now responds to the speed switch and will spin fast and slow but it still wont trigger the Deceleration Switch (X19 bit 5).
    I found another wire on the bottom of the control that looks like it was stuck on the M20 pins as well. It's a grounded jumper. Two wires are hooked together and then go to ground. Can anyone that has a Yang with a rotary table please have a look at the M20 plug on the I/O Board and see if you have any wires attached to it. I know pins 4,20,25,29,39,and 40 are all Rotary table related but don't have a clue where this jumper could tie into.I am confident it goes somewhere on the M20 slot. Fanuc doesn't have a clue. I see nothing in the electrical schematic that I have other than the pin 25. This machine just has a mickey mouse set up where they are pushing the wire right onto the pin, doesn't have a proper Honda style plug into the I/O board.
Page 2 of 2 12
  1. fanuc alarm 1000 mcb trip
    By dhiruj in forum Fanuc
    Last Post: 09-12-2012, 10:24 PM
  2. Need machine parameters for vmmc-1000 with Meldas MO control
    By WEBBERS_14 in forum MetalWork Discussion
    Last Post: 08-14-2009, 08:20 PM
  3. strippit cap 1000 with fanuc 0p control
    By jaimeeduardo in forum Fanuc
    Last Post: 08-10-2009, 05:04 PM
  4. Yang Eagle 1000, Program numbers?
    By Ess Express in forum Fanuc
    Last Post: 04-22-2009, 09:11 PM
  5. Replies: 5
    Last Post: 09-02-2008, 02:36 PM
